timing
Old Nov 20, 1999 | 09:59 AM
jesse's Avatar
jesse
timing
O'k, call me stupid. but when I put my 351M back together I must have forgotten the timing pointer which mounts to the engine block. well, its in Louisiana and I'm in Germany. I need to get the timing as close as possible, when I get the timing set good the carb is all messed up and vice versa. I only have 1000 miles on the truck and the carb is new to. Any advice on timing this engine.
Old Nov 20, 1999 | 10:14 AM
deleontow's Avatar
deleontow
timing
No, but seriously, hows about I just send you on, send or email me your address and I will find one in our yard and mail it to you.
Dave
<a href="http://members.aol.com/deleontow/auto/index.htm">http://members.aol.com/deleontow/auto/index.htm</a>
Old Nov 20, 1999 | 08:42 PM
ole65's Avatar
ole65
timing
If you don't locate a stock marker, you can make your own at any convenient point on the block. It is all relative as you can have your custom marker and custom mark on the damper. Then lay out the BTDC degrees that you want, The secret is getting the engine to top dead center on cylinder number one to locate your TDC mark. If you do use a factory marker and an old damper, make sure the rubber hasn't slipped or else you will never get the timing back.
Old Nov 20, 1999 | 08:45 PM
rick's Avatar
rick
timing
arkysarge
Oct 16, 2014 01:51 AM
Frank A.
New Member Introductions
Apr 28, 2013 10:19 PM
rbloodhound
Louisiana Chapter
21
Aug 3, 2007 10:09 PM
SFC DAVIS
Florida Chapter
Apr 20, 2004 06:54 PM
UncleJesse
Dec 23, 2003 10:36 PM
