pitnam arm removal
Old Dec 18, 2019 | 05:55 PM
  #31
hjartland's Avatar
hjartland
Good so far
The hardware store bolts. Are doing well. All good to date.
Old Dec 18, 2019 | 06:40 PM
  #32
sloopdog1's Avatar
sloopdog1
Grind the dirt and paint 1 inch from the crack, with the crack being in the middle, all the way around it, make a clean circle. Then grind the length of the crack , not all the way thru, now practice on some steel that is close to the same thickness as the frame.
Weld the first bead in the crack from one end to the other. Make a 2nd pass on the right hand side of the first weld, overlapping the first weld. Make a 3rd pass on the left hand side of the first weld, overlapping the first weld.
Let it cool, repeat until you are happy.
Old Dec 18, 2019 | 06:58 PM
  #33
hjartland's Avatar
hjartland
will do if needed.
I'll do that if it seems to spread. But it was going straigh to a bolt hole. No signs of spreading elsewhere.
2001SuperDuty
Jan 31, 2019 01:12 AM
DaytonaTunnel
Aug 18, 2014 10:28 PM
bmacky14
Jun 22, 2009 08:41 AM
blankman
Aug 7, 2006 07:48 AM
RomerB2
Bronco II
Jul 2, 2005 01:03 PM
