Sponsored by: Auxito
HELP::: IAC GASKET QUESTION
Old Sep 10, 2019 | 01:49 PM
travelmaster's Avatar
travelmaster
Help me out....
I recently replaced idle air control gasket. Package came with 2.
Is there a second gasket on the iac? Am i overlooking something?
Do you happen to know if i replace the iac with a new one, do the new ones typically come with gasket(s)?
Thanks for your expertise!
Old Sep 10, 2019 | 06:45 PM
Chevy_Eater's Avatar
Chevy_Eater
I can't say specifically about your part, but usually when a part comes with multiple gaskets it means the part has more than one application and that the installer uses the gasket appropriate to the current installation.
To verify this match your two new gaskets together and see if there are any differences. Only takes one really minor difference. If so then match your old gasket up to the new one that's the same then use that one.
Old Sep 10, 2019 | 07:55 PM
azroxx's Avatar
azroxx
I installed a Hitachi valve and it came with 1 gasket, which I promptly dropped into the center area and was a pain to get out. So watch out for that when you have your fingers way back in there and your tongue out and toes crossed while trying to get it aligned enough to start the bolts. Maybe I should have used a light adhesive as well?!
Old Sep 11, 2019 | 09:31 AM
alloro's Avatar
alloro
You only need one gasket. If the two gaskets are identical they might've dropped two in by mistake. Think of the poor sap that bought the box before or after yours, that one could be missing the gasket.
randinow
Jul 27, 2010 09:10 PM
kawa
1983 - 2012 Ranger & B-Series
Apr 23, 2010 07:56 AM
johnny dangerous
Oct 27, 2007 10:07 PM
rews2
1978 - 1996 Big Bronco
Jul 14, 2005 09:21 AM
F250reddog
Jan 13, 2004 08:31 AM
