Fluctuating Idle UPDATE
Old Apr 22, 2010 | 10:04 AM
kawa's Avatar
kawa
Talking Fluctuating Idle UPDATE
Several months ago and up to the other day my "98 4.0 Ranger has been plagued with this idle surge coupled with the A/C cutting on and off.
https://www.ford-trucks.com/forums/9...ating-idle.htm.
Paw Paw gave me some great fix-it advice but that only lasted as a short fix. I finally bit the bullet and bought a new IAC valve all to no avail, problem still existed.
I once again cleaned the old valve with plastic safe cleaner but this time I removed the vent cap, cleaned both vent filters. I once again dried everything with low pressure air and reassembled the valve and re-installed it on the engine.
Now, the mounting pad on the engine has an "O-Ring" laying in a groove and in the past I had always relied on this to act as a sealing gasket by lightly coating it with grease before re-assembly.
This time I installed a paper gasket on top of the O-Ring, re-installed the freshly cleaned IAC valve and VIOLA! Fluctuating idle is gone and has been for several hundred miles.
Your guess is as good as mine as to what the actual cure was but for my money it was the "Gasket". I'm not going to dis-assemble it to remove the gasket to test my theory, I'm just too happy hat the fluctuation is gone.
Rog
Old Apr 22, 2010 | 10:25 AM
Rockledge's Avatar
Rockledge
I know that O-ring gasket that you are talking about, it's kind of flimsy. It reminds me of the stringy upper intake gaskets, which also fit into grooves.
(Some aftermarket IACs come with a different style gasket, BTW).
Good feedback, hopefully you solved the issue for good. If so, it might be worthwhile for people with similar issues to try a new gasket before changing out the IAC.
Old Apr 23, 2010 | 07:56 AM
pawpaw's Avatar
pawpaw
Good feedback on your IAC problems.
Interesting theory about the IAC "O" ring seal, as I too have wonderd about the oem seal taking a "set" & flat spotting & maybe not sealing well.
My new IAC came with a flat paper gasket & I too installed it over the OEM "O" ring seal.
I still have my oem IAC, that I could never find a visual problem with, so I'm of a mind to go break it out & do a step by step recleaning, including the "vent filter" under the little black cap, which I never removed to clean & see if my oem IAC will revive & if not then use the paper gasket on it & see what happens!!!!!
Chevy_Eater
82
May 21, 2025 08:15 AM
SpartanDieselTech
Apr 10, 2014 09:41 PM
dpassarella
Mar 30, 2014 07:55 PM
asemastermech
175
Dec 11, 2013 12:08 PM
bunruh
Nov 1, 2013 06:24 PM
