Starting issues (hot starting)
Old Sep 9, 2019 | 01:59 PM
Taylor Doyle's Avatar
Taylor Doyle
79 f150 custom/302/manual trans.
I have had some issues this summer of the truck starting just fine on cold start getting to the dump and a near by store, then when coming out to head home I get a really slow crank and it will not turn over. I sit and smoke a couples cigarettes and try again it will crank and go on down the road. I just bought a starter solenoid and starter today to throw at it and also found some corrosion on the cable from the starter to the solenoid which will be fixed. Battery bench tested good but may need other ideas.
Old Sep 9, 2019 | 03:41 PM
Tedster9's Avatar
Tedster9
Beware el-cheapo solenoids! More trouble than they are worth. If ignition base timing is too far advanced, this can cause trouble with higher compression engines. If any of the starting and ground or battery cables are original (or old enough to buy tobacco) they should be replaced. Heat soak is a problem but can be minimized with good cables of adequate size. If you can check starter current draw, about 100 or 150 amps or so is all they should pull.
Old Sep 9, 2019 | 03:45 PM
jakeharp's Avatar
jakeharp
Had bad hot start issues with my big FE starter, just put in a power-master hi-torque mini starter, this thing starts the truck before I can get my hand off the key, and I can get it in and out without removing headers or tranny, unlike the big hunk of metal that was stock...
Old Sep 9, 2019 | 04:35 PM
Taylor Doyle
Well after the first post I did what I do best and Started tearing the beast apart. First item was the solenoid. Cleaned the frame and all connections, trimmed cable to the starter that had green crusties and fitted a new connector. (Will replace when I can find a nice roll of 2ga wire for all battery connections) and installed. Fired right up first crank. Let run untill engine temp got up. Normally at that point is when it gets dicey starting back up. Shut her down and fired right back up again and again. Have let run a few times while sipping a cold one or two and was able to shut off and crank up no issues. Now the question is do I go ahead and change the starter out too since I'm already in the mood and have the parts on hand. Or let it fly. I do not know how old the starter that is installed is.
Old Sep 9, 2019 | 04:41 PM
Tedster9's Avatar
Tedster9
See if you can find someone to borrow one of those clamp on ammeters, if you don't have one, they are slick. Most people don't have the tools to measure a couple hundred amps. No sense spending money replacing a perfectly good part. Problem today, "new" or "rebuilt" doesn't mean too much.
Could easily end up installing a shiny new defective starter to replace what you have on there now. One clue to a defective starter is they start drawing way more juice than spec.
Old Sep 10, 2019 | 09:16 AM
1978f-250's Avatar
1978f-250
If the starter is not a problem I'd leave it alone.
Dennis
laloacosta
May 3, 2021 08:16 PM
Glaser67
Oct 21, 2017 10:04 AM
2_Tone
18
Mar 20, 2016 01:13 PM
B-one
Dec 5, 2006 08:33 PM
carnagez28
Aug 25, 2006 08:10 AM
