Hot Start Problems
Old Feb 28, 2016 | 10:16 AM
2_Tone's Avatar
2_Tone
Hot Start Problems
Hi again. Nearing the end of the father/son project on the 74 f250. One of the last hang-ups is it's unwillingness to restart once warm. It cranks slowly, but reliably when cold and will start over and over. Once it's been on the road for 10 minutes or so, it will still crank slowly, but not start up.
So, I've been doing a bunch of reading and seen vapor lock and a hot starter most often listed as the cause of this kind of thing. I'm leaning towards starter, because the engine doesn't die or seem fuel starved when warm and as long as I don't turn it off, I can keep driving.
Before replacing the starter, I was thinking that maybe wrapping the exhaust at the point it passes the starter might work. I know this is likely wishful hoping for a cheap and easy fix, but I'm trying to be optimistic.
Any thoughts/advice would be great.
Old Feb 28, 2016 | 01:41 PM
1978f-250's Avatar
1978f-250
Your engine should not crank slowly when cold so there's a problem there before it's warmed up. I would suspect poor/corroded connections and check all cables to starter and battery. Make certain the ground is also clean and tight.
I'm not certain of the reason for the no-start when warm but somebody here will help with that.
Dennis
Old Feb 28, 2016 | 01:56 PM
whomrig's Avatar
whomrig
It seems to me that 1978f-250 is headed in the right direction. check ALL connections, take a good look at the starter go from there
Old Feb 28, 2016 | 02:09 PM
ubereal2's Avatar
ubereal2
That engine turning over slowly has nothing to do with vapor lock.
I'm wondering more like you have a weak starter, or battery. As already mentioned make sure your connections are clean and tight.
Unk Bob
Old Feb 28, 2016 | 04:09 PM
ZarK-eh's Avatar
ZarK-eh
What about the Battery Cable and Ground Straps?
They might look ok, but inside the insulation it might be a corroded mess...
Old Feb 28, 2016 | 04:19 PM
FordFanboy's Avatar
FordFanboy
I have the same issue. I put on a starter blanket but it didn't make a big difference.
Old Feb 28, 2016 | 04:49 PM
Blue and White's Avatar
Blue and White
When they are warmed up and then sit, fuel in the carb can boil. That can make hot re-start harder. Usually a good crank and maybe hold the throttle open a bit clears it out, re-fills the fuel bowels and you are in business.
Agree it sounds like there is weakness in the starting system. Connections, condition of wires, battery, starter or solenoid.
Old Feb 28, 2016 | 09:33 PM
2_Tone's Avatar
2_Tone
Thanks for the advice from all. I'm confident that the cables to and from the battery and solenoid are OK. They are all brand new and while I know that is not a guarantee of a good connection, I would be surprised to find that they are the issue.
Assuming for a minute that heat to the starter is the issue, what do any of you think about the idea of wrapping the exhaust? Will that dissipate enough heat, or is it a waste of money?
Also, if heat to the starter is an issue, how does a new starter help the problem? Won't is also get hot? Is a newer starter simply more tolerant to the heat because of its "newness"?
Old Feb 28, 2016 | 09:51 PM
OldOrange's Avatar
OldOrange
Timing could also be an issue. They will start Good when cold. But once they warm up they can crank hard and slow and show symptoms similar to that of a dead battery. Timing set to far advanced can cause the same issue.
Old Feb 28, 2016 | 10:24 PM
burnthelight88's Avatar
burnthelight88
As someone already said, it shouldn't crank slowly when cold. I'd replace the starter if you are insistent that the cables and battery are good. You really only specified cables to the solenoid and battery are new...what about the cable to the starter?
A lot of guys are going with the PMGR mini-starter.
If you're literally looking to do the minimum possible, I have heard that header heat wrap in the starter area has worked for some people.
Old Feb 28, 2016 | 10:30 PM
mountain dewd's Avatar
mountain dewd
Like OldOrange said, it sounds like timing, that was the problem with mine.
Old Feb 28, 2016 | 11:21 PM
Tedster9's Avatar
Tedster9
New cables may not be the cure-all. One problem is that some manufacturers are now using extra thick insulation to make it appear like good quality cable, but it is not. Cheap cable is never a bargain. A worn out starter is going to have trouble in hot weather, too. Slow (excessively slow) starting when cold means either bad grounds and connections, a bad starter, or both. You have to measure for "voltage drop" (look it up, trust me) while under load to see what's going on.
Overly advanced timing might be the issue but if not, if all the other solutions have been tried - 2/0 cable (about .353" thick) ground and starter cable has been recommended as an effective remedy in troublesome "hot start" situations. Works every time, or so I'm told. $5 bucks a foot, so hide the CC statements.
http://www.allbatterysalesandservice...cfm/4,508.html
Old Feb 29, 2016 | 06:16 AM
vtpkrat2's Avatar
vtpkrat2
I have learned to never ASSUME anything is proper when new or "I checked that" a while back. A methodical checking of things pointed out in replies should track down the problem. That means actually removing each bolt or cable connection and cleaning etc,etc.
You'll get it, just don't hop around to this and that. Eliminate things one at a time.gary
Old Feb 29, 2016 | 06:57 AM
Blue and White
A comment on wrapping... it is effective in reducing surrounding heat and creates more heat in the manifold material. It may cause cracking of the manifold. A shield may be a better solution. That said, most of these trucks work OK so suggest you continue the troubleshooting.
Old Feb 29, 2016 | 01:34 PM
hdgapeach's Avatar
hdgapeach
As the others mentioned; clean all grounding terminals and the locations they connect to.
Forget the exhaust wrap. It'll just speed up the rotting of the exhaust pipe/header (whichever you have). They make a heat shield for the starter that may help a little. Mini starters will give you more room around the exhaust, too.
You want to find out if your problem rests with the starter itself? Make sure all the electrical connections are good to go. Make sure the battery is fully charged. Start it up and run it just like you always do. After it gets good and warmed up (operating temp), bring it back to the house and shut it down near a water hose pipe. Immediately try to start it while everything is good and hot. If the usual still occurs, spray the starter with the hose until you can feel it's cooled down. Then attempt to start the truck again. If it fires right up, your starter is failing you. If you still can't start it with the starter cooled, the other comments about the timing will more than likely be valid.
Used to have to perform the water trick on a '76 Lincoln Cont. for a while!
Good luck.
