Transmission Fluid
Old Sep 6, 2019 | 08:15 PM
eutecticpt's Avatar
eutecticpt
Transmission Fluid
I have red fluid leaking out of a tube near the transmission on a 1994 IDI. I just had the power steering pump replaced--could it be related? Wife is not happy.
Thanks
Old Sep 6, 2019 | 08:51 PM
hairyboxnoogle's Avatar
hairyboxnoogle
There is a power steering "cooling loop" and using atf in power steering is pretty standard... unfortunately, none of the system is near the trans. Most likely the cooler lines rubbed a hole in eachother
tecgod13's Avatar
tecgod13
Power steering is all up front of the engine. It is possible that they bumped a transmission cooling line and that triggered the leak, but if the tube was rusty enough to break, it most likely was on its way out....
Sounds like someone else did the pump for you, you may be able to convince them it was their fault.... or they may point out the line is rusty and they aren't liable.
Old Sep 6, 2019 | 09:20 PM
eutecticpt's Avatar
eutecticpt
Yes the pump was replaced at a shop. They also replaced the lower radiator hose. So it could be power steering fluid that is draining out of the tube in front of the transmission?
Old Sep 6, 2019 | 09:24 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
it's on the wrong side to be a transmission line from the looks of your picture
Check the PS fluid level.... that much it should be empty soon what ever it is
Old Sep 6, 2019 | 10:15 PM
genscripter's Avatar
genscripter
Don't let dumbdumb kid mechanics work on your mechanical truck. They are only good for plugging things in and looking up codes. They don't know how to turn a wrench.
Old Sep 7, 2019 | 08:12 PM
solanum's Avatar
solanum
If that's an E4OD, there's a line pressure test port at about that location, it might've backed out or something.
Old Sep 8, 2019 | 08:42 AM
eutecticpt's Avatar
eutecticpt
The red fluid was leaking from the small tube in this photograph. Any suggestions for a simple fix?
Old Sep 8, 2019 | 10:44 AM
eutecticpt's Avatar
eutecticpt
Vent/Drain for Flywheel cover
Apparently the fluid leaked from the Vent/Drain for Flywheel cover. Research indicates that the front pump gasket or seal may be leaking, I recently changed the starter--any possible connection? I put two quarts to Mercon V in to the transmission and was able to drive the truck for a short time. The transmission shifts into reverse reluctantly and shifts into drive more easily. Since I don't know how many miles are on the replaced transmission, not sure is I want to invest is having the seal replaced. Anyone know how much replacing the seal costs?
Old Sep 8, 2019 | 11:10 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Oh OK that makes more sense .. better picture
when the E4OD over heats it's known for Puking Fluid out the front seal, sometimes they kinda fix themselves but if it a continuous thing then you probably gonna have to replace the seal....( this means dropping the tranny)
I don't see how it can be related to just changing the starter
maybe time for a fluid flush and change.
Old Sep 8, 2019 | 12:11 PM
catfish101's Avatar
catfish101
I have seen these transmission loose front seals instantly. My 94 did when I was moving hay. The seal showed no signs of any deterioration. No bushing issues. Swapped the seal and have been going ever since.
Been awhile but I am thinking it was a seal you install dry. Make you use something like nonchorinated brake cleaner and blow the sealing surface dry. Don't use a rag and wipe it off.
Old Sep 9, 2019 | 07:47 AM
Olds64's Avatar
Olds64
x2
Here's a good video on DIY transmission flush:
If you have to drop the transmission to replace the front seal you MAW rebuild the entire thing. E4ODs don't have a reputation for being all that strong.
ID Scrounger
Large Truck
Apr 24, 2019 12:41 PM
runawayhound
Jan 1, 2016 06:30 PM
abyars111
Apr 16, 2013 05:36 PM
Impac
Aug 9, 2007 12:00 PM
BigClint
Dec 5, 2004 03:39 PM
