Steering Sector Info
Old Sep 6, 2019 | 02:02 PM
Daggers's Avatar
Daggers
Has anyone a clear photo and if possible an overall measurement of the 1937-48 steering sector shaft/gear assembly part no. 78-3575.
Going to see a friend next week who has a box of assorted sector shafts but don’t really want to pull my box apart to get some photos/sizes. A clear photo of gear assembled on shaft and an overall length would allow me to expand photo to full size to compare with parts.
Old Sep 6, 2019 | 05:14 PM
newold46's Avatar
newold46
I have no measurements but I do have some pictures of when I tore mine down. Not sure if they can help you but...
Old Sep 7, 2019 | 06:02 AM
bernette's Avatar
bernette
only picture i found , my truck is a 2 ton and bushings were bigger.
Old Sep 7, 2019 | 01:52 PM
Daggers's Avatar
Daggers
Thanks for the info guys.
Looking at the PU today I was trying to work out how to get the steering box/column removed.
Has anyone removed a box/column from a complete PU, is it possible?
I can jack up the front end but not sure if the box will pass over or under the axle.
Old Sep 7, 2019 | 02:32 PM
newold46's Avatar
newold46
It is a one piece affair. I had to jack up the front of the truck to get it out. I'm pretty sure it went under the axle.
Old Sep 8, 2019 | 03:00 PM
Joe777's Avatar
Joe777
Been a long time but I recall threading mine up thru cab floor and out driver side door because we could not get the steering wheel off.
Old Sep 9, 2019 | 04:13 AM
Daggers's Avatar
Daggers
Lee - will try this weekend to raise PU and see if I can get the box under axle, looks tight.
Joe - did you have the engine in the PU when you removed the box?
Old Sep 9, 2019 | 08:00 AM
tacomacream's Avatar
tacomacream
Here is some more info: https://www.ford-trucks.com/forums/1...ng-column.html
Old Sep 9, 2019 | 09:50 AM
newold46's Avatar
newold46
It came out pretty easily from what I recall. No steering wheel of course. The whole thing, tube and all, I think. It was a while ago.
Old Sep 9, 2019 | 07:26 PM
Joe777's Avatar
Joe777
Yes the engine was in it. I should have said earlier that this is a 1.5 ton truck so there may be more room in that than in a pickup.
Old Sep 19, 2019 | 06:37 AM
Daggers's Avatar
Daggers
Hi All
just to confirm above, today I raised the front axle 19” above ground and removed complete steering box/tube from pickup without problems.
Rebuild is now underway.
Thought I would post as it might give someone confidence on steering removal from a complete vehicle.
Old Sep 19, 2019 | 08:27 AM
newold46's Avatar
newold46
Hi All
Nice work! Having a one-piece steering column creates some fun, doesn't it?
vonhef
Sep 2, 2019 08:38 AM
gochappy
Sep 19, 2017 09:59 AM
tl1965
Nov 26, 2015 07:15 PM
glovemeister
18
Sep 24, 2013 09:00 PM
itsjustagreat1
Jan 31, 2009 12:02 PM
