Sponsored by: Real Truck
Ignition/key trouble
Old Sep 4, 2019 | 11:26 AM
rghouse's Avatar
rghouse
so the 2000 F-250 V10 has never liked anything but the stock key I got when I bought it (2 years ago), any copies are a huge pain to get the ignitin to turn over to start. Ok no problem, use 1 key (pain for wife).
Last week the truck went in because the turn signal switch in the steering column went out a while back. $300 bucks later I have signals again but my ignition is even worse than before. My key will only turn to start if I try it a couple of times or get it just right with pushing in and twisting as I enter key into slot. The spare key has no chance at all now. The ignition makes a click that you can feel after it turns a bit now also. The mechanic said he had to take the ignition apart to change the signals switch/arm and I know he sprayed some sort of lube into the ignition because he said "it was sticking", and there is fluid on the key. This is a real pain and I want to get it remedied before I sell it.
Do I need a new iginition? Is this fixable?
Old Sep 4, 2019 | 11:37 AM
projectSHO89's Avatar
projectSHO89
You need a new ignition cylinder. Sounds like yours has excessive wear.
Old Sep 4, 2019 | 11:52 AM
rghouse's Avatar
rghouse
Ok. Looks like I can get an OEM lock cylinder on Amazon for $36.
I can install this and match original tumbler pattern and i dont have to re-key and add new door locks?
My auto door locks do not work and I have no transponder for it.
RBerry9511
Feb 7, 2020 04:31 PM
86f250xl
Large Truck
Apr 2, 2015 06:15 AM
TexFinn
19
Feb 8, 2015 09:09 PM
93Sunplex
Feb 27, 2007 06:17 PM
johnlynn
Dec 27, 2003 10:17 PM
