Crank no start
Old Sep 2, 2019 | 08:47 PM
Bob Warner789's Avatar
Bob Warner789
Originally Posted by Yahiko
Take the clutch cover off the front of the compressor and if the bearing is still okay you can run that way.
I believe the compressor is locked up because it just so happens that I did take the clutch off first and tried to start it with no luck. Then I ended up taking off the serpentine belt and it fired right up.
Huge relief knowing what was wrong Because I just bought the truck a few days ago in Tennessee and ended up stuck here in Maine because of this. Will be calling a shop in the morning to try to get it towed there and get it fixed. Hopefully it won’t cost too much.
I really appreciate everyone’s input because I don’t know if I would’ve ever ever figured it out on my own.
Old Sep 2, 2019 | 10:04 PM
Yahiko's Avatar
Yahiko
You can replace the clutch idler pulley and just not put the clutch disk back on and it will run.
The bearing is not a cheap one and it is less to just do the clutch.
Blackjack8
Nov 11, 2017 09:33 PM
Cms300
Jun 7, 2016 01:12 PM
Uppal6
Jul 15, 2015 02:18 PM
dirty661
Sep 16, 2010 12:26 AM
BigBlue04
Oct 20, 2009 07:55 AM
