A/C confusion
Old Sep 11, 2019 | 03:55 PM
jurish's Avatar
jurish
Originally Posted by charles adams
When I run my front a/c unit (dash) I'd say the cool air is a 6 out of 10, but when I run the front a/c and the rear a/c together, my cool air in the front is a 8 out of 10.... what can I do to get the front unit to function colder without having to run both units?
I can confirm this phenomenon in my 05 X. I actually measured the drop when I turned on the rear AC. I think what is going on is that with the rear AC off, the expansion valve back there is closed and the system becomes unbalanced. There is no fix. If you look at the schematic for the system, both front and rear evaporators are just "T'ed" with no real way for the refrigerant to decide where to go. If you just run the rear fan at low, that should be enough airflow through the rear evaporator to keep the expansion valve open and the system balanced.
Old Sep 11, 2019 | 07:11 PM
01__Excursion's Avatar
01__Excursion
I had pondered this exact scenario, but you are correct without the rear fan running, the TXV closes, and in effect should prevent the excess refrigerant needed to saturate the rear coil and simply have it sitting in waiting from the Tee back, meanwhile the front system should have what it needs to operate prior to the tee off to the rear. Still doesn't explain the situation unless there is a slight low charge, or an air flow issue through the evap coil which would cause improper TXV operation.
Zacbkennedy
Jun 19, 2017 10:52 AM
Frantz
2014+ Transit
Sep 3, 2015 11:18 AM
Joco
19
Dec 8, 2011 05:20 PM
rnelson664
Feb 14, 2008 09:02 PM
theGman
15
Apr 12, 2005 04:55 PM
