When I run my front a/c unit (dash) I'd say the cool air is a 6 out of 10, but when I run the front a/c and the rear a/c together, my cool air in the front is a 8 out of 10.... what can I do to get the front unit to function colder without having to run both units?
Install ball valves that shut off hot coolant from flowing through the heater cores. One between hard line on passenger side and heater core inlet and one under degas bottle before it goes back into the Y. This will eliminate ALL hot coolant from flowing through the cores and heating up your air. In winter just open them up and you will have full heat when you need it.
I don't have a good answer for you, but I have found that to be the case with every dual A/C vehicle I've ever had experience with. Dad had Chevy conversion vans in the mid 90s that were that way and I had a '99 and an '06 E-150 that both worked that way as does my '00 Ex.
The front might seem to be colder when the rear is running only because the rear is pumping additional cold air into the cabin. To correctly check you need to use a thermometer in the center vents and see what it reads.
I'll second this.
My 2000 Ex puts out 38 degree air from the in-dash vents. (The thermometer may be off a couple of degrees, but that's irrelevant.) When I turn on the rear A/C, the temperature coming out the front vents doesn't change, but the entire Excursion is cooler.
The inside of an Excursion is a lot of cubic feet of air to cool with an A/C system that has most parts in common with one cooling the cab of a pickup.
I guess this calls for some checking out. It just so happens I have a calibrated thermometer that I use for work. I'll check it out when I'm off this freaking train and home.
You wouldnt happen to have pics of where I need to install these valves would you?
I'm sure there's videos of how to do this for the v10 also. Saw a couple a while back. Can even vacuum operate it so it works properly without needing to manually do anything.
If you want to block the coolant flow more than the factory valve already does there is no need to block both the inlet and outlet, and doing could cause problems. Just block the inlet and coolant can no longer flow.
Most likely what you're feeling is because the rear AC is helping the front one so it seems like the front one is working better when the rear is on.
Nonsense, I’ve had both in and out blocked during spring and summer for three years with no issues. What would it possibly hurt?
Anyone got the high and low side pressures for a properly operating Ex?
Not meaning to hijack, but surely that would be a good starting test point assuming both front and rear evaps are clean and clear.
There are exact pressures based on the 134A Freon T/P charts, but it's not a good reference point because pressures are greatly affected by temperatures, IE: airflow over each coil, ambient air entering the evap coil, ambient air entering the condenser coil, and by possible internal flow issues IE: dirty strainer, malfunctioning TXV. If the super-heat and sub cooling engineering values are a known quantity for that system, than you can perform those tests. Otherwise you could recover the charge, evacuate the system to 300 microns or less, and re-charge by weight per the rating plate to know you have a correct charge.
