6.2 long idle harm/considerations?
Old Aug 27, 2019 | 03:16 PM
Section179's Avatar
Section179
My day can include hours of call/email time that don’t always make sense to go back to a building for. My truck has been panning out to be a fantastic mobile office and I’m comfortable on my phone and laptop for hours at a time.... with one catch. Often I need the vehicle running to stay comfortable.
So, before I start racking up idle hours... in a 6.2, what are the implications of idling for as much as 50% of hour-wise usage? Does setting up the high-idle mod do anything for longevity? Should I just suck it up and get double-layered or naked as required?
thanks!
Old Aug 27, 2019 | 03:20 PM
MJAB's Avatar
MJAB
I wouldn’t worry about it other than just watching the temps. Look at police cruisers, they probably spend half their life or more just idling. I saw a crown Vic one time that had over 14k idle hours. They started putting those on in later to years to specifically track the number of idle hours for maintenance purposes.
Old Aug 27, 2019 | 04:07 PM
spongecop's Avatar
spongecop
Semper Fi
Our fleet has alot of these 6.2 trucks and they just change the oil every month due to the high idle time...same for police vehicles.
Old Aug 27, 2019 | 04:47 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
The fleets I work with running gas trucks are on a 300 hour service interval, so far its been working out well for them. This is F-150s with 5.0's and Super duty trucks with 6.2 and 6.8 engines.
Old Aug 27, 2019 | 05:57 PM
Crabbman P's Avatar
Crabbman P
Gritting naked and coats would save alotta gas and hours though.
Old Aug 27, 2019 | 06:36 PM
Section179's Avatar
Section179
Thanks for the feedback!
in addition to engine hours and more frequent oil changes I wondered if there was a minimum RPM for proper oil circulation that for fuel efficiency regular idle falls below.
Our mini and Volvo (turbo charged, super and turbo charged tiny *** engines) aren’t supposed to be idled for long. So I was thinking it might be a situation where I should be setting up a high idle or something. Granted, this American truck has three times the engine of either the mini or Volvo....
Old Aug 27, 2019 | 06:55 PM
Andy_george's Avatar
Andy_george
My $.02 is that you’re fine. Keep the oil changed regularly and keep a general eye on stuff, but the 6.2 idling very frequently is a MUCH better option than the 6.7. Today’s diesels get much more crabby just idling than they used to, with the lower combustion temps wanting to mess with the $$$$ after treatment stuff.
Old Aug 27, 2019 | 07:06 PM
ford390gashog's Avatar
ford390gashog
No harm, it's much preferable to idle a newer gas truck than a diesel. At least you won't foul the egr cooler or DEF.
Old Aug 28, 2019 | 12:00 PM
dnewton3's Avatar
dnewton3
There is no legit reason to use a high-idle feature just to sit and use the truck as a mobile office. Even with the AC running, there's enough charging capacity that it should be fine.
High-idle is a tool for trucks with a LARGE amount of amps being drawn, or running PTO take-off equipment. You are doing neither.
As for the oil change cycle, just follow the OLM. Of all the UOAs I've seen on this engine, there's nothing to concern yourself with. The oil system does a good job in the 6.2L.
Old Aug 28, 2019 | 04:41 PM
tibadoe's Avatar
tibadoe
I would change the oil more frequently.
dirthawg
6.7L Power Stroke Diesel
13
Oct 7, 2020 09:47 PM
jim48
32
Jun 28, 2015 11:58 PM
Joe Meg
Oct 25, 2010 05:32 AM
Acftmaintainer
Sep 9, 2010 06:39 PM
PowerstrokeJunkie
Nov 7, 2008 05:04 PM
