T-5 transmission
Old Aug 26, 2019 | 11:35 AM
86bullnose4x4's Avatar
86bullnose4x4
T-5 transmission
Has anyone with a 6.9 idi or 7.3 idi tried swapping out their stock c6 or t-19/t-18 transmissions with a Borg-Warner T-5 instead of doing the ZF swap?
Old Aug 26, 2019 | 02:57 PM
DarkOverCast's Avatar
DarkOverCast
T5 is light duty trans
The only ones I can think of off my hand you could potentially swap with the right adapter and have it last would be nv4500/5600 zf5/6 and way back when Clark made some medium duty trans with an overdrive but they were rare as hell. Maybe Spicer even did back then. Most were overdriveless
Old Aug 26, 2019 | 03:42 PM
86bullnose4x4
Oh okay. I just saw something about the t5 and was curious if anyone had. A little more research showed they were mostly in ford gm and Dodge cars. I had also looked at maybe a fuller 10 speed but it maybe be better to just swap my c6 for a t19 and and a gear vendor kit. Nothing against the c6 just prefer standard shift over auto
Old Aug 27, 2019 | 02:02 AM
solanum's Avatar
solanum
My '92 has the original S5-42 transmission, it's a really slick setup with just the right gear ratios and all 6 gears are synchromesh. They're a little spendy to get used, once you factor in the clutch, pedal, steering column, crossmember, and driveline parts you're gonna need.
The 4 speed boxes are nice with a gas engine, but you'll end up with the same ****ty gear ratios as the C6, so it's not really worth the trouble IMO.
If you want the best result, duplicate the S5-42 or -47 setup using as many factory parts as possible. Second best, IMO, would be a Clark 5-speed. You can buy them for $500 all day long, and most of the hardware used with them is compatible with our trucks. They're mostly set up with a mechanical clutch linkage AFAIK, so if you wanted Ford hardware, you could use the pedals from an early '80's T-18-equipped F-or E-series truck. They shift like a box of rocks, as does the T-18/19, but they'll last forever in a small truck.
I'm not a huge fan of those overdrive boxes if you couldn't tell, but some folks seem to like them. For the love of God, though, don't put one behind the C6. It has no lockup, and you're just making more heat and wasting power by increasing the torque needed to drive the wheels.
Old Aug 27, 2019 | 05:05 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Would not want that trans behind a diesel. They were used with the 300 and 302, even the 351 got the ZF ( and 460)
Old Aug 27, 2019 | 05:44 AM
hairyboxnoogle
While obviously lockup would be better, assuming a factory or near converter, it stalls 800-1200 rpm, once over that point there is no more or less slip at 1500 than there is 3500. Aux od is a boon even in a vehicle with a higher stall converter, you just have to take care that you cruise above the stall speed. ALL OD whether aux or not, auto or not, has higher parasitic loss than direct, and by lower the final gear, gives less torque multiplication from the gears requiring more power to move the vehicle. The trade off is obviously lower engine rpm and increased economy, this doesnt change just because its behind a c6.
All that said, im personally no fan of the aux od boxes, unless its a doug nash behind a manual, even then, preferably one that already has OD
Old Aug 27, 2019 | 07:25 AM
hturner12's Avatar
hturner12
I am doing and E4od to t 19 swap.
https://www.ford-trucks.com/forums/1...-t19-swap.html
Old Aug 27, 2019 | 09:04 AM
86bullnose4x4
Well I appreciate all of y'all's feed! I've seen pages I'm pages for zf swaps but never heard of a Clark transmission. Are they hard to come by? And I'll also check out the E4od to T19 swap forum as well.
Old Aug 27, 2019 | 10:28 AM
solanum's Avatar
solanum
No, millions put in f700/800 trucks, commonly available from truck scrapyards
Old Aug 27, 2019 | 12:47 PM
86bullnose4x4
Oh okay awesome. Thanks for the information.
Old Aug 27, 2019 | 08:57 PM
DarkOverCast
I was under the impression the clarks were an sae bell housing pattern, so wouldn't I need that adapter? Plus whatever junk for the mechanical clutch on the trans side?
And shift like a box of rocks the t19 does not. I don't touch the clutch unless I'm taking off and it doesn't care, the same can't really be said about the zf5/6 as it's got tighter tolerances
Old Aug 29, 2019 | 08:41 AM
RaymondIV's Avatar
RaymondIV
There were different sizes of Clarks, in fact back in the Stone Age when you could special order components I knew of a rancher who had bought a new Ford pickup with a Clark transmission. Most F & C 600 to 800 Ford trucks had Spicer 5 speeds with 2 speed rear ends.
davedart
Feb 9, 2019 04:25 AM
SgtOtaku
16
Aug 19, 2017 08:01 AM
dcelrod
23
Sep 10, 2015 09:03 PM
nebechanezer
Feb 11, 2006 04:03 PM
