Sponsored by: Real Truck
Rail Fuel filter stuck
Old Aug 25, 2019 | 03:21 AM
Hoople79's Avatar
Hoople79
I have a 2015 F250 6.7 diesel. I went to change the rail fuel filter using a 32mm sicket as recommended, I cranked on it with everything I had and it would not budge. I then used my 20V drill driver it did not budge, I even went as far as using ,my 1/2" air drive impact at 120psi and the darn thing wouldn't move! Any suggestions on what to do would be greatly appreciated.
Old Aug 25, 2019 | 10:25 AM
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
At this point before I did anything else I would order a new bowl, they’re not crazy expensive. Then I would take a 1/2 breaker bar with a piece of pipe on the end of it and yank like hell on it. You may get a better response / different ideas asking this question in the 6.7 forum.
Old Aug 25, 2019 | 07:02 PM
senix's Avatar
senix
I have in the past used the socket and a flexable oil filter wrench to removed mine. That was the first filter change.
The o ring was not lubricated. Since then they are a breeze when you use some oil on the o ring.
You will probably break yours before you get it off so as suggested a replacement on hand is advised.
Old Aug 25, 2019 | 07:59 PM
Just Strokin's Avatar
Just Strokin
There are two fuel filter cups Either will work I do believe.
fuel filter cup
FC4Z-9G270-A
BC3Z-9G270-D
Old Aug 26, 2019 | 02:10 AM
Hoople79's Avatar
Hoople79
Thanks all for the suggestions and the part numbers. I will order a new bowl up and give these a try,
Old Aug 26, 2019 | 01:48 PM
Rod Jr.'s Avatar
Rod Jr.
Use either air or electric Impact drive like you would use for removing wheels.
bobv60
May 1, 2016 02:22 PM
onug
Modular V10 (6.8l)
Sep 9, 2011 10:08 PM
SmOkIn(EM)OUT
Oct 28, 2009 08:56 AM
QRFleader
1983 - 2012 Ranger & B-Series
Feb 26, 2004 09:06 AM
lordconqueror
Sep 8, 2000 01:12 AM
