Help
Old Aug 18, 2019 | 05:28 PM
spock152's Avatar
spock152
Help
I have a 1990 f 150 standard truck with a 5.0 engine , 4 days ago it started raining i rolled up the windows started the truck and turned on the AC . it ran for about 10 mins then it died . it will not restart . i have no gas pressure , no spark . it will just spin . i have replaced the E C M. And the coil. Still nothing . i am at my witts end anyone got any ideas as to what is going on ?
Old Aug 18, 2019 | 05:42 PM
My4Fordtrucks's Avatar
My4Fordtrucks
You have made diagnosis of this issue much more difficult since you have already started throwing parts at it instead of troubleshooting the problem. You should have tried to retrieve fault codes with the original computer to see what happened. Why did it shut off: did it run out of fuel (maybe a bad pump?) or did the ignition system die? Did it blow a fuse? I’d there a problem with the EEC power relay or wiring?
Now to try and figure out if you got a good computer from the parts store.
Try pulling KOER codes from this computer and post them.
Old Aug 18, 2019 | 05:44 PM
spock152's Avatar
spock152
Help
Since it will not start and or move i cannot get it to any place to run a diagnostic on it
Old Aug 18, 2019 | 05:56 PM
bluepiggy's Avatar
bluepiggy
not sure if your truck model and year has one but check inertia switch if you have one.
Old Aug 18, 2019 | 06:02 PM
spock152's Avatar
spock152
Not sure either .
Not sure either . would not know where to even start looking for it .
Old Aug 18, 2019 | 06:07 PM
My4Fordtrucks
You can get fault codes in your driveway using a paper clip. See post #2 in this thread :
https://www.ford-trucks.com/forums/1...esitating.html
Old Aug 18, 2019 | 06:57 PM
torq'ta 5 8's Avatar
torq'ta 5 8
drive side fire wall to the left of brake/clutch/gas pedal
look something like this
Old Aug 18, 2019 | 09:58 PM
bluepiggy's Avatar
bluepiggy
yup that's it thats where its at
Dorian Critchlow
Mar 27, 2017 12:25 PM
CJPA
Sep 25, 2011 11:04 AM
vibrancy
Nov 6, 2010 09:02 PM
rtpalin
1997 - 2003 F150
Feb 18, 2008 11:50 PM
shadowflyer
Sep 5, 2005 12:56 AM
