Heater box removal
Old Aug 17, 2019 | 06:56 PM
CJ McGee's Avatar
CJ McGee
Heater box removal
Hello! I recently removed my heater core in my ‘64 f100 because it was leaking. I believe it has the standard heater. I have now decided to clean my floor/firewall and paint with POR15. I also would like to install the firewall cover from LMC and begin installing insulation.
I am having trouble locating any bolts to remove the heater assembly. I can see one bolt on the drivers side, and possibly two nuts behind the battery.
Any advice to help remove the box would be appreciated!
CJ
Old Aug 17, 2019 | 09:22 PM
User 71024's Avatar
User 71024
pretty sure the box has 3 studs in a triangular pattern threw the firewall with nuts on the outside..
Old Aug 17, 2019 | 10:48 PM
62SY4's Avatar
62SY4
That is my recollection as well. Fine threaded and surely rusty.
Old Aug 18, 2019 | 10:13 PM
F100 '64's Avatar
F100 '64
Hey CJ, here's a link to my video where I pulled the box out for a rebuild. There are 3 studs that go through the fire wall and 1 bolt. I point them out in the first 4 minutes if you don't want to watch the whole video. Good luck. ~Pat
Old Aug 18, 2019 | 11:42 PM
CJ McGee's Avatar
CJ McGee
I have actually watched many of your videos! I find them to be incredibly informative.
Thanks everyone for the replies! I located the bolts and plan to pull the box soon. I'm in no rush because it will take some time to replace or repair the heater core. Does anyone have a spare laying around? If the shop can't fix mine then I will be in the market for another.
CJ
Old Aug 19, 2019 | 01:53 PM
benbuilder's Avatar
benbuilder
I have an extra one from the parts truck I purchased. email me at chircolandinc@gmail.com
Old Aug 19, 2019 | 08:55 PM
F100 '64's Avatar
F100 '64
CJ
Thanks CJ!!! From what I understand the '64 heater cores are not available anywhere. I put a link to another member who converted a newer core to work in our trucks. It starts about 8-10 post into the thread. I also saw another post converting a newer core but can't find it right now. ~Pat
https://www.ford-trucks.com/forums/1...ater-core.html
Old Aug 20, 2019 | 07:17 PM
Oilboy34's Avatar
Oilboy34
I replaced the heater core in our 65 from one from NAPA. It leaked worse than the 50 y/o one. It was made in China. Shop around and find one from USA would be my advice unless you like changing it twice.
1993 ford
Jun 1, 2017 08:46 PM
hinzr
Mar 3, 2014 10:33 PM
Paul Therriault
Jan 24, 2006 07:55 PM
Hammerhead
Aerostar
Dec 10, 2003 04:54 PM
sanman68
Mar 2, 2002 08:59 AM
