How to fix this rust spot?
Old Aug 17, 2019 | 03:27 PM
JoeKan's Avatar
JoeKan
This is on the passenger's side hood. I'm not sure how the pin holes got there. What would be your recommendation on attacking this? Sand, then filler? Or is it too thin??
Old Aug 19, 2019 | 06:00 AM
alltrucksexpert's Avatar
alltrucksexpert
First of all, you should remove all these hanging pieces of paint, or what it is. And then with some kind of tool from rust to handle it. I saw how the rust is removed Coca-Cola
Old Aug 19, 2019 | 05:01 PM
JoeKan's Avatar
JoeKan
Thanks! I'm going to buy 3m paint and rust stripper and try that.
Old Aug 19, 2019 | 05:35 PM
JalopyJake's Avatar
JalopyJake
That whole area needs to be gone over with 36 grit on a high speed sander to get rid of flaking material/rust. If it's too thin in the rusted area then you have several options including light DA sanding followed by a chemical treatment such as Evaporust or Ospho. Whatever you do though you're gonna have to cut the flaking junk out and get back into solid material to feather it into.
Old Aug 20, 2019 | 04:55 AM
alltrucksexpert
Now, when everything is already removed, try to make the surface as uniform as possible. Then the applied paint will serve you well
Old Aug 20, 2019 | 06:00 AM
JoeKan's Avatar
JoeKan
Right on! appreciate the help. I plan to attack the rust tomorrow )
Old Aug 22, 2019 | 11:38 AM
irhunter's Avatar
irhunter
Can we get a larger-scale pic..with the camera pulled back?
You'll probably need to do work to the underside, too.
Is the intent a 25-foot paint job, or what?
Roy
Old Aug 23, 2019 | 10:37 PM
JoeKan's Avatar
JoeKan
Roy
I took pictures of it tonight and for some reason I can load them on this page, not sure what I'm doing wrong?? I'm planning on restoring this as much as I can. I would really like to take off the bed and have it blasted but not sure if I can do that or not? I know there is no way I'll take the cab off.
Old Aug 24, 2019 | 08:18 AM
irhunter's Avatar
irhunter
Boy, that looks pretty rough, to me.
If I was doing it, I would remove all the paint and as much rust as I had the time for. If, at that time, there was any rust left (micro-pits or rust "blush"), I would start with something like POR or Chassis Saver.
My take is, starting with some rust plus Chassis Saver will never end up giving you a great paint job...but, might be rust-free for pretty long.
I would look hard for a less-rusty hood.
Roy
Old Aug 24, 2019 | 06:41 PM
JoeKan's Avatar
JoeKan
Here's a better shot of it. I think it downloaded this time.
File Type: html
Old Aug 24, 2019 | 08:30 PM
JoeKan's Avatar
JoeKan
Then again, maybe not
taylor90
17
Mar 4, 2011 12:37 PM
berry1234
Paint & Bodywork
Aug 3, 2010 05:08 PM
AlaskanEx
Apr 3, 2010 10:39 PM
wickedinhere
Paint & Bodywork
Nov 29, 2008 01:19 PM
66MercMan
Oct 20, 2004 07:19 PM
