Tailgate not latching unless slammed - Adjustment?
Over the years my tailgate has gotten tougher to latch closed. I really need to slam it now to get it to stay closed. I've tried moving the striker pins outward but that doesn't seem to do anything. Maybe I'm not moving them into the "right" spot? Maybe there's an issue with the latches? Thoughts on how to best determine what the real issue is and best resolution?
Take the cover plate off the inside side of the tailgate and you should be able to see the problem. Sandy
What Sandy said. Plus you can straighten the rods out and lubricate everything inside the tailgate at the same time. Mine was the same way when I got it and lubing and straightening the rods resolved the issue.
Thanks for adding the lubing Part. Also the side latches on the tailgate.
Mine was getting harder and harder to open and close. I went to open the gate and the handle broke. What caused the handle to eventually break was the fact that the “handle control assembly” was dry. Lubing the control with lithium grease freed it up. With the new handle and the control greased up it easily opens and closes.
So is it the thought that the rods are hanging up and it's the slamming that is causing them to release? I hadn't really considered that as a scenario - figured it was more that the latch/pin were worn and/or not correctly oriented. But I was loosing faith in that premise after trying a different set of latches and moving the latch pins all over.
Not in my case. It was the mechanism in the center of the tailgate that changes the direction of the handle pull to the rods. Lubricating that helped tremendously.
I can identify with the swaybacked pony deal, it seems that if you've unhooked your goose trailer, shut the tailgate to disconnect the trailer wires, you should open the tailgate before you drive off................ I did a really good job on the gate, plus pulled both bed sides in. Porta powers can be useful............. Larry
Another quick note, since the tailgate seems to be the center of discussion. I bought a tailgate torsion bar from LMC this spring, after my wife bummed the truck for some furniture hauling, and had trouble lifting the gate. That is the best 30 bucks I've ever spent. Super simple install, can't see unless you look between the gate and the bed. I can lift the gate with my little finger and when opened, you guide it down with the same finger. It REALLY works well
I have a Bronco so I don’t think the pickup tailgate is heavy.
My pickup tailgate used to be very straight until I hauled a few loads of firewood. Now it has a slight bend.
Thanks for the input.
I didn't know what my issue was. Mine was only latching on one side when it did latch at all and the handle was very stiff. Straightening the rods and lubing everything solved all my tailgate issues. Well, except for actually lifting it when my arms are full of stuff. Going to order one of those tailgate lift assist thingys someone else mentioned.
Got the cover off tonight and found that I was having precisely the same issues. Once the center mechanism was lubed up everything works great now. When I first got to it, the left side was totally seized up and never latching; it was only the right side that was latching when it got a good slam. Now both sides latch with the lightest of force.
If only all fixes on this truck were this simple!?
Ha ha! Lithium grease on the hood latch mechanism does wonders for that as well. I have the opposite problem when the hood latch is dry...the hood won’t pop open.
