Tailgate Handle
Old Apr 21, 2013 | 10:28 PM
86'F-150's Avatar
86'F-150
Tailgate Handle
Does anyone else have to hold the tailgate handle open in order to close the tailgate and get it to latch shut? I'm trying to figure out what part needs replacing. I've noticed that the handle has sunken into the recess a little.
Old Apr 21, 2013 | 10:38 PM
dohc_chump's Avatar
dohc_chump
This space for rent...
Mine would have to open in order to close it. Actually, mine does open, it just requires an act of God and the alignment of the planets. I'm sorry, I'm of no help tonight.
Old Apr 21, 2013 | 10:47 PM
ctubutis's Avatar
ctubutis
Might lube up all the metal-to-metal contact points, including in the mechanism and where the tailgate's latches meet the bed.
Old Apr 22, 2013 | 10:30 AM
1986F150six's Avatar
1986F150six
I agree with what Chris suggested and will add that I find it much easier to do this by removing the tailgate and turning it upside down [might want to place on an old blanket to protect the finish].
Old Apr 22, 2013 | 02:15 PM
86'F-150's Avatar
86'F-150
I lubed everything up pretty well and didn't notice a change. If I shut the tailgate without holding the handle in the open position the gate just bounces off the bolts. If I shut it holding the handle in the open position and release the handle when it's all the way closed then it will securely latch closed. I think the actual handle mechanism is broken, especially the way it's sunken into the tailgate the way it is.
Old Apr 22, 2013 | 02:56 PM
dylansf23's Avatar
dylansf23
Ours decides to lock itself so we will have to hold the handle and go to the right side and pull the lever up and then it closes fine
Old Apr 22, 2013 | 03:28 PM
Skoiv's Avatar
Skoiv
Mine is in good condition and out of habit, I always pull the handle before closing. I just hate to slam it. It doesn't close very well either when not using the handle.
rob17
6.7L Power Stroke Diesel
Aug 27, 2016 07:01 PM
ungerp
Jan 25, 2013 10:45 PM
bf5113
Aug 14, 2005 07:24 AM
stephenw
Feb 16, 2003 07:05 PM
