Real Problem with over size tires
Old Aug 15, 2019 | 01:03 PM
msmith55's Avatar
msmith55
In June I purchased a 2011 F150 4x4 3.7. When I took it for the test drive I noticed that the speedometer was off. After checking it with a GPS app I found that it was off by 12 to 15 mph. The kid I was buying it from had the thing recalibrated from the factory size 235/75/17 to the ones he had on which were 265/70/17 which was fine. That was until last week when I had to clean the battery terminals. It went back to being off again. After research I learned about Forscan. I picked it up and followed the spread sheet info. I found the BCM line 726-12-01 mine looked totally weird. It was as follows ( 0000-000F-4F) . When I changed the middle set it said invalid. I thought that the code sequence was to be 4 characters in each. Please if someone could give me the correct sequence, I really need your help.
Old Aug 15, 2019 | 02:09 PM
driximus's Avatar
driximus
Not all of the 09-14 trucks will change in Forscan. I was trying to get my 14 to change tire sizes also but mid 2014 and up have better success when trying to change tire sizes.
Old Aug 15, 2019 | 03:21 PM
00t444e's Avatar
00t444e
Something wasnt calibrated right, a 235/75/17 is roughly 31" in diameter and a 265/70/17 is about 32". That's less than a 4% difference in diameter, for you speedometer to be off 12-15 MPH just from the tire change you would have to be going over 150 MPH.
Old Aug 15, 2019 | 04:38 PM
steve(ill)'s Avatar
steve(ill)
00t444e is right........ those two tires would be a difference of 2 MPH at 100 MPH.... not even worth a reprogram.
Old Aug 15, 2019 | 05:20 PM
Siberexpress's Avatar
Siberexpress
I think you need to check what you have in it for rear end gears and see what they are or ask the guy what he changed them to.
Old Aug 15, 2019 | 09:53 PM
cmorningstar01's Avatar
cmorningstar01
As those above have stated the speedometer error for the difference in the 2 tires is negligible.
Speedometer Difference
Speedo ReadingActual Speed
20 mph (32.19 km/h)20.47 mph (32.95 km/h)
25 mph (40.23 km/h)25.59 mph (41.18 km/h)
30 mph (48.28 km/h)30.71 mph (49.42 km/h)
35 mph (56.33 km/h)35.83 mph (57.66 km/h)
40 mph (64.37 km/h)40.94 mph (65.89 km/h)
45 mph (72.42 km/h)46.06 mph (74.13 km/h)
50 mph (80.47 km/h)51.18 mph (82.37 km/h)
55 mph (88.51 km/h)56.3 mph (90.6 km/h)
60 mph (96.56 km/h)61.42 mph (98.84 km/h)
65 mph (104.61 km/h)66.53 mph (107.08 km/
https://www.tacomaworld.com/tirecalc...5r17-265-70r17
Old Aug 17, 2019 | 08:40 AM
meborder's Avatar
meborder
Put your. Gauge cluster in “engineering test mode” and scroll through to the electronic speedometer.
Compare that to the gauge.
whiteboydrew
Feb 1, 2017 05:34 PM
LTTLMAN
Apr 15, 2005 07:39 AM
Cpt. Chaos
Bronco II
Jun 1, 2004 12:46 PM
T_Moss
Apr 2, 2003 10:29 AM
captjon
1997 - 2003 F150
Aug 9, 2002 02:29 PM
