Transfer case chain stretch?
Old Aug 7, 2019 | 09:53 PM
JoSHN's Avatar
JoSHN
I've got a 2010 raptor with the 5.4L that is starting to turn into a money pit. It's actually been the wife's truck since new, and 8 years of mud and air have taken its toll.
We are currently getting a metallic noise coming and going while driving. Only during a steady cruising speed. When you left off the gas, the noise instantly drops. The noise is similar to a chain being dragged on metal, or marbles rolling down a metal slide?
As far as parts or places to check, I have already replaced the following parts within the last year: both front hub assemblies, front and rear brakes and rotors, both IWE actuators, upper control arms, and had the front shocks rebuilt. Sadly, they were all changed for a reason and not just guesses. The wife is just really hard on the truck.
Could this be the chain stretching inside the t-case? If so, is there a difference in t-cases compared to a regular f-150? Or could this be transmission related? I have checked fluid levels, colors, etc on both and nothing was out of the ordinary or low. I'm at a loss on ideas. Any help?
Old Aug 8, 2019 | 11:32 AM
jpv859's Avatar
jpv859
Sounds like you may have a vacuum issue at the IWE's. May have a weak solenoid or a cracked or chaffed vacuum line. I done a few that chaffed the lines near the upper control arm next to the inner fender guard. Had a solenoid on my truck give a noise concern also. You can try running and switch into 4wd to see if it goes away or unplug the vacuum hose at the solenoid and see if the noise goes away.
Old Aug 8, 2019 | 11:55 AM
JoSHN's Avatar
JoSHN
I've heard the IWE noise on my 08 F150 and this doesn't not sound the same at all. I will check the vaccum lines tonight and see if I can get the noise to change switching to 4wd.
Old Aug 9, 2019 | 08:16 AM
alloro's Avatar
alloro
Originally Posted by JoSHN
When you let off the gas, the noise instantly drops. The noise is similar to a chain being dragged on metal, or marbles rolling down a metal slide?
Sound more like an issue with the pinion bearings in the rear axle.
Old Aug 10, 2019 | 02:23 PM
JoSHN's Avatar
JoSHN
What would be the best way of checking this without popping the cover off?
Old Aug 18, 2019 | 12:13 PM
alloro's Avatar
alloro
About all you can do is see if there are signs of fluid leakage and disconnect the driveshaft to check the pinion for excessive play.
