Cutting a hole for fuel pump access!! -->Measurements<--
Old 11-02-2023 | 11:45 AM
OBSession05's Avatar
OBSession05
I removed the bed for the frame swap. Every bolt spun when I tried to remove the nut. I had to cut the head off of all six bolts.
Sadly that's very true. I've been pretty lucky on my 94 but both the spare tire and receiver hitch I had issues with seized bolts. On the bright side, they can't be stuck if they're liquid
Old 11-02-2023 | 12:36 PM
jhrsmail's Avatar
jhrsmail
Same here, when I replaced my bed, I used super duty bed bolts that had allen keyed heads and captured nuts. Lots of anti-seize... still don't want to lift it up just to check voltages on fuel pump.
Old 11-03-2023 | 05:24 PM
JehD's Avatar
JehD
Originally Posted by OBSession05
Well unless I missed it everyone also has another option. Take off the bed? .
That's all I ever did in the past and not really take the bed off but remove the bolts on the left side and loosen them a bit on the right. Lift the bed up a little and wedge a 4x4 chunk between the bed and the frame.
The following users liked this post:
mecdac
Fifth Wheel & Gooseneck RV Towing
08-21-2021 01:14 PM
PRUSue
11-15-2015 10:05 PM
andgott
19
09-10-2013 11:04 AM
Can DO
01-05-2010 11:48 AM
56_Toy
18
02-13-2006 11:06 AM
Quick Reply: Cutting a hole for fuel pump access!! -->Measurements<--
