Bogging when shifts
Old Aug 6, 2019 | 03:58 PM
Mayhem01's Avatar
Mayhem01
Bogging when shifts
Ok, here is what is happening. I have a 2001 7.3 with 83,000 miles on it. Yesterday I was heading home when I pulled off from a stop sign. The truck shifted normal from 1st to 2nd. When changing from 2nd to 3rd (auto trans) when it shifted to 3rd it felt like an engine brake was activated. I drove for a bout 1 mile, pulled over looked under the truck & checked the fluid level. All normal. got back in the truck and the same thing happened again. I could slow down (below 20mph) and it would downshift to 2nd and all was normal. Speed up to where it would shift to 3rd and bog again as if an engine brake was engaged. I can manually shift the truck to 2nd and run 40+ until I shift back to "D" on the column. I removed the T&S chip HOPING that would be the issue. But it was doing the same thing when shifting 2nd to 3rd. The RPMs of the engine do not go up but I can accelerate and I still lose speed and it feels like the "brake" is applied stronger. Any ideas as to what might be going on. I am the 3rd owner of the truck and I have had it since 53k miles. Never had an issue like this before. Also had a mechanic friend of mine rode with me and he has never seen anything like this either. He agrees that it seems like an engine brake/exhaust brake is activated. Any advice would be greatly appreciated.
Old Aug 6, 2019 | 04:23 PM
Colorado350's Avatar
Colorado350
@Mark Kovalsky Probably has some ideas, he seems to know these transmissions pretty well.
Old Aug 6, 2019 | 05:52 PM
Bonanza35's Avatar
Bonanza35
Never heard of that, like to see what Mark says. But did it smoke when this happen? That would lead it to the EBPV for sure.
Old Aug 6, 2019 | 08:49 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The Exhaust Backpressure Valve (EBPV) is my guess. I can't think of a way the transmission could do this.
Old Aug 6, 2019 | 08:57 PM
z31freakify's Avatar
z31freakify
Sticking caliper slide pins?
Old Aug 6, 2019 | 09:06 PM
Mark Kovalsky
That only stick after the 2-3 shift? Seems farfetched to me.
The EBPV is electronically controlled. It's possible that there is some cross feeding of power that is enabling the EBPV when the 2-3 shift is commanded.
Old Aug 6, 2019 | 09:09 PM
z31freakify
Missed that part Mike
Old Aug 7, 2019 | 05:51 AM
Mark Kovalsky
Who's Mike?
Old Aug 7, 2019 | 08:40 AM
timmyboy76's Avatar
timmyboy76
Originally Posted by Mark Kovalsky
Who's Mike?
You know...Mike, the Mark transmission guru
Old Aug 7, 2019 | 12:52 PM
z31freakify
Lololololol Sorry Mark.
Old Aug 7, 2019 | 07:34 PM
dmd's Avatar
dmd
Wire the EBPV open and try again, the easy way to test it..
I think mine fell off...
Old Aug 7, 2019 | 08:09 PM
Mayhem01's Avatar
Mayhem01
Thanks for the replies. I am thinking it will be the EBVP from what y'all are describing. I now just need to find it on my truck. I will try to take a video of what it is doing before I fool with the EBPV.
Sincerely
Dale G
PS. I will let y'all know what the verdict is. Again, thanks so much for any advice.
Old Aug 8, 2019 | 12:36 PM
Bonanza35's Avatar
Bonanza35
Good luck Dale, hope we helped!
Old Aug 8, 2019 | 12:45 PM
Tugly's Avatar
Tugly
He's describing a time about when the TCLU occurs. Still nothing possible there?
Old Aug 8, 2019 | 04:16 PM
Mayhem01's Avatar
Mayhem01
video
I hope you can tell something about the video
File Type: mov
