Sync/Navigation Display Seems Washed Out
Old Aug 3, 2019 | 11:57 AM
StuartT's Avatar
StuartT
On my 2017 F350 Lariat, the display, especially in Navigation mode, seems like the brightness control is set to high and contrast is set to low. Is there access to settings for the display which I have failed to find?
Old Aug 3, 2019 | 12:31 PM
GABAR's Avatar
GABAR
Have you gone into the settings menu?
Hit settings, scroll to the left, hit display, hit brightness, then adjust to your liking.
I’ve found that by switching the screen to always being in the night mode, everything is easier to see in the daytime so try this before you adjust the brightness.
I hope this info helps you out.
Have a great day.
Old Aug 3, 2019 | 12:59 PM
StuartT's Avatar
StuartT
Since I posted, I did find the lost "Display" menu (I was not swiping to the left) and adjusted the brightness. Not much effect. I called Ford and they said there were no further settings available to me. So I just went out and tried your suggestion to go to night mode. My first reaction was not favorable, but after looking at it for a while, I started to warm up. I am going to give it a try for a few days and see how it works out. Thanks for the tip.
Old Dec 11, 2020 | 11:42 AM
UWBob's Avatar
UWBob
Have a great day.
Yes, brightness is grayed out.
Old Dec 11, 2020 | 11:49 AM
UWBob's Avatar
UWBob
I had to argue with them for a very long time, they finally said that they were going to look into it. I cannot believe that on an $80k+ vehicle you cannot adjust the brightness, I have a very cheap tablet (about $69) and I can even do it on that. There is a brightness slider but it is grayed out and does NOT work. This is a DEFECT, we should not have to find a work around, they need to fix it, it is only a software problem.
Old Dec 12, 2020 | 07:16 AM
StuartT's Avatar
StuartT
If you get any further feedback from Ford, please post. I am still not happy about this.
Old Dec 12, 2020 | 08:19 AM
UWBob's Avatar
UWBob
Update: Ford just called me, yes they really did. It looks like they are looking into the problems with the Sync 3 screen, I would suggest that if you have any problems with your sync screen you can contact them on facebook "chat": https://www.facebook.com/ford/ and hit the "Messenger" button. The more complaints we send them the better chance they will do something faster.
Thank you all for all the help, but please don't stop I can use all the information I can get.
Old Dec 12, 2020 | 09:11 AM
UWBob's Avatar
UWBob
Another update: Here is the contact information for the gentleman that is my contact, if anyone would like to call, or email him he goes by "Rick"
Lockhart, Kenneth (K.) <klockha4@ford.com>Rick | Customer Experience Specialist | Houston CRC
866.631.3788 x79068
klockha4@ford.com
EFax : 866.609.8767
Mon-Fri 10:30AM TO 7:00pm CST
THANK YOU ALL!
Old Dec 12, 2020 | 10:15 AM
StuartT's Avatar
StuartT
Appreciate your carrying the ball with Ford. I for one will send an email to Ken supporting your efforts. But first I have to go take another look at my display. Been a while since I fussed about it, I need to refresh my memory.
Old Dec 12, 2020 | 10:41 AM
UWBob's Avatar
UWBob
Sounds good! Thank you for the support! Let us know what happens.
Old Dec 14, 2020 | 07:16 PM
UWBob's Avatar
UWBob
Hey brothers, I could use a little help here. If anyone has a problem with their sync 3 screen being to bright, and have to use it in night mode all of the time please respond here. We will not get anything done unless we band together. I have given a lot of information on this forum, But we have to stick together and let each other know what is happening. Now if you love the way your sync is working, then you do not need to to anything, but if you are having a problem, or think something could be better please post it here. I will try to keep things going, but I need support.
Thank all of you !
Bob
Old Dec 15, 2020 | 10:41 AM
StuartT's Avatar
StuartT
I have just sent an email to Rick Lockhart (see UWBob's post #8 above) asking that I be included regarding the requests for Ford to look into the brightness and contrast issues with the Sync 3 displays. YOU can too!
Old Dec 15, 2020 | 03:44 PM
UWBob's Avatar
UWBob
Thank you!
UWBob
Dec 21, 2020 02:28 PM
4wheelfurry
2015 - 2020 F150
Mar 21, 2020 02:25 PM
GABAR
2015 - 2020 F150
Oct 4, 2018 08:37 PM
robin locksley
Feb 13, 2018 10:19 AM
aquaman
2009 - 2014 F150
Jan 6, 2011 11:41 AM
