Sync/Nav display brightness madness
The problem I have on my '10 Sync/Nav unit is it tends to want to default to maximum brightness more often than not, regardless of what I had it previously set. I find myself constantly reducing display brightness every time I start the truck.
I notice during sunrise or cloudy days a few different scenarios happen
- automatic headlights on, display is set to max brightness.
- headlights manually turned on, display is at maximum brightness with the + and - dim controls disabled. If I flip the headlight switch to auto, the display is max and the dimming controls are active. However, if I need the headlights on regardless of outside light, I can't change the brightness
- as the sun rises and outside light gets brigher, my display will alternate between max brightness and what I set it. Annoying!
Do any of you see this on your units? This is clearly a software/firmware configuration thing. Dealer says this is normal operation. The service advisor duplicated it on one of his trucks in his lot and send Ford Corporate a message. I told them it's a huge driving distraction at night because my cabin is lit up like a beacon. Ford Sync helpdesk says it's not their problem. WTH?!?
