2020 Sync 3 screen brightness slider grayed out
Old Dec 9, 2020 | 04:50 PM
UWBob's Avatar
UWBob
I just bought a 2020 F-350 Platinum, and the 8" Sync 3 screen is so bright during even the day time it is distracting. I have gone through the settings found the “auto, day, night” settings and I can turn it to night mode during the day, and that does dim the screen some. I found the screen brightness slider, but it is grayed out and unusable. This makes the day mode completely unusable. I’ve taken it to the dealership, and they said all of them are that way. Does anyone know if this defect is across the board? I even had a chat with Ford on facebook, but basically all I got from them is; we don’t care oh well. We are not going to even look into the problem. Does anyone have any idea on how to fix the brightness control? Thank you all for any suggestion/ help you can give.
Old Dec 9, 2020 | 04:57 PM
GABAR's Avatar
GABAR
Thats definitely not normal and since they said it was, you should have asked to see another SD on the lot with SYNC 3 and compare.
With that being said, have you tried a Master Reset of the SYNC 3 system?
Do you know how to do this?
Do you use Apple CarPlay or Android Auto and if so, are you still having the same problems?
Old Dec 9, 2020 | 04:58 PM
ford390gashog's Avatar
ford390gashog
The screen brightness control only works when the headlights are on.
Old Dec 9, 2020 | 05:03 PM
UWBob's Avatar
UWBob
Yes, I did a master reset. No I have not used android auto, I don't know what that is. The service manger at the dealership said that all the new ones did the same thing. I'm starting to think it is a software defect.
Old Dec 9, 2020 | 05:07 PM
UWBob's Avatar
UWBob
Oh, so it is a defect, During the day in auto of day mode it is way to bright, In night mode if I have everything dimmed as far as it will go, it is ok, still a little bright but ok. I'm a pilot and I do not like my night vision diminished in any way.
Old Dec 9, 2020 | 05:12 PM
GABAR's Avatar
GABAR
Very interesting.
Apple CarPlay and Android Auto is an interface that takes the place of the stock SYNC 3 interface on the center stack.
All you have to do is plug your cell phone into the USB slot below your radio and like magic, you’ll get a new screen.
If you have an iPhone or an Android smart phone, just plug it in.
It might improve your what you’re seeing now because of the new interface.
Do you use navigation on your phone?
Old Dec 9, 2020 | 05:15 PM
shawnee1's Avatar
shawnee1
Just wondering, is the brightness slider greyed out because it is in "auto" mode? I haven't tried this so have no idea. Just guessing.
Old Dec 9, 2020 | 05:47 PM
UWBob's Avatar
UWBob
Originally Posted by GABAR
Very interesting.
Cool I will try that, I have an android. Yes I do normally use google maps on my phone as this is the first truck I've had that has nav.
Thank you!
Old Dec 9, 2020 | 05:50 PM
UWBob's Avatar
UWBob
Well, to answer your question no it is grayed out in auto, day and night mode, I think it will work in night mode with the headlight on, but not sure.
Old Dec 9, 2020 | 07:19 PM
UWBob's Avatar
UWBob
I think you are correct, which makes it a defect, and needs a recall.
Old Dec 9, 2020 | 07:30 PM
ford390gashog
Sounds like you would benefit from the other versions of Sync 3 themes. I have mine set to Ford GT and its dark blue in the day and black and white at night. The brightness slider does work with the headlights on. The Lincoln theme is also nice but hard for me to see in the day.
You can play with all of them using the diagnostic mode and then use forscan to set it permanently.
https://www.ford-trucks.com/forums/1...-software.html
Old Dec 9, 2020 | 07:33 PM
UWBob's Avatar
UWBob
OK, please if you would tell me how to change it, and where can I find the themes. Will everything else still work?
Thank you!
Old Dec 9, 2020 | 07:39 PM
ford390gashog
Thank you!
Press "Next Track" button on steering wheel controls and "Next Track" under the infotainment screen at the same time for about 10 seconds. A Speaker Test will start. Press End Test. Then a menu will pop up. If you select "Enable Test Settings" this hidden menu will now be a choice on your normal settings menu. Test settings is where you can view all the information on the Sync and temporarily adjust the screen theme. You will need forscan to set it permanently.
Old Dec 9, 2020 | 07:49 PM
UWBob's Avatar
UWBob
Press "Next Track" button on stirring wheel controls and "Next Track" under the infotainment screen at the same time for about 10 seconds. A Speaker Test will start. Press End Test. Then a menu will pop up. If you select "Enable Test Settings" this hidden menu will now be a choice on your normal settings menu. Test settings is where you can view all the information on the Sync and temporarily adjust the screen theme. You will need forscan to set it permanently.
OK thanks, I will try it and see what happens. I know nothing about the forscan, sorry.
Old Dec 10, 2020 | 04:25 PM
GABAR's Avatar
GABAR
Thank you!
Awesome...... I think you’ll prefer it over the stock SYNC 3 interface and Google Maps are far superior than the factory navigation. You’ll also be able to use Waze as well.
After you plug your phone in, you might have to go into the settings menu and tap Android Auto.
Let us know if you have problems.
