This hose is chafed and cut.. what is replacement #?
if your only point of chafe is where the electrical tape is... save yourself some $$ go to the plumbing section buy a 60*/90* double barb brass fitting and 2 hose clamps... thats all i did for mine when the hose split at the corner from rubbing against the turbo boot clamp. came out to less than $3...
i would also advise pulling the CAC tube and flipping the clamps around so the bolt comes up from the back side.. thatll keep them from chafing the hose again.. ntm make it easier for road side repairs.. since theyll then be pointed towards you instead of away..
The following users liked this post:
sunuvabug
08-24-2017 07:31 AM
SpeedJunky
07-03-2007 09:49 AM
mtbiker
09-17-2003 07:32 PM
