This hose is chafed and cut.. what is replacement #?
Old 07-30-2019, 07:59 PM
Powerstroke2004.5's Avatar
Powerstroke2004.5
Powerstroke2004.5 is offline
The hose from engine to degaser. What hose is this? Was bumping on the clamp bolt on turbo boot.
Old 07-30-2019, 08:17 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
I don't think there is a convenient hose, I replaced mine with some Parker 3/8 fluid hose and a Parker abrasion sleeve.
Old 07-30-2019, 09:44 PM
bismic's Avatar
bismic
bismic is online now
Received 2,585 Likes on 1,798 Posts
03-07 F Series: HOSE ASSEMBLY - EGR cooler to the vapor space the degas bottle: 3C3Z-9Y439-AD
Old 07-30-2019, 11:28 PM
Sparky83's Avatar
Sparky83
Sparky83 is offline
if your only point of chafe is where the electrical tape is... save yourself some $$ go to the plumbing section buy a 60*/90* double barb brass fitting and 2 hose clamps... thats all i did for mine when the hose split at the corner from rubbing against the turbo boot clamp. came out to less than $3...
i would also advise pulling the CAC tube and flipping the clamps around so the bolt comes up from the back side.. thatll keep them from chafing the hose again.. ntm make it easier for road side repairs.. since theyll then be pointed towards you instead of away..
The following users liked this post:
Old 07-03-2020, 11:44 AM
F350 1990's Avatar
F350 1990
F350 1990 is offline
OK ..............fix
Old 07-03-2020, 11:54 AM
TooManyToys.'s Avatar
TooManyToys.
TooManyToys. is online now
Received 2,168 Likes on 1,465 Posts
Different hose 90, Mark got it right for this thread, you posted for another.
Old 07-03-2020, 01:27 PM
Mich6.0's Avatar
Mich6.0
Mich6.0 is offline
reposition turbo clam and put a piece of vacuum hose on the threaded portion of clamp
sunuvabug
08-24-2017 07:31 AM
woodys06
07-19-2009 10:52 AM
SpeedJunky
07-03-2007 09:49 AM
mtbiker
09-17-2003 07:32 PM
Quick Reply: This hose is chafed and cut.. what is replacement #?
