Sponsored by: Real Truck
Front Wheel Bearings
Old Jul 29, 2019 | 08:10 PM
Kountryguy's Avatar
Kountryguy
I have a 2011 F-350 crew cab drw pickup. How often should the wheel bearings be checked and repacked?
Old Jul 30, 2019 | 07:02 AM
Djosbun's Avatar
Djosbun
I am not aware of anyone that re-packs wheel bearings on a given schedule (every xx,xxx miles, for example). With even the best quality wheel bearing being not expensive at all, you are probably better off replacing them once they start making a little noise. Every wheel bearing I have ever replaced had close to 100,000 miles on it.
I check my wheel bearings at every tire rotation. Recently did a rear brake job and even though the bearings weren’t making any noise I replaced them anyway, since I was replacing rear rotors, parking brake components, etc.
— Dave
Old Jul 30, 2019 | 07:37 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
If you have a 2wd drw I would repack the front bearings every 50K, the rears are lubed with the rear end grease and should last the life of the truck or the rear end. If you do it yourself the dust caps on a 2wd DRW are a bear to get off and I haven't found a tool to get them off easily, the rest I sraight foword but the hud rotor assy is heavy so be prepared.
Denny
Old Jul 30, 2019 | 08:27 AM
saratoga2011's Avatar
saratoga2011
Worth mentioning if it's a 4WD truck there is no checking or re-packing the front bearings. They have unitized bearing/hubs that simply get replaced when the bearings begin to fail.
Old Jul 30, 2019 | 09:47 AM
Kountryguy's Avatar
Kountryguy
It is a 2 wheel drive and thanks for the replies.
Old Jul 30, 2019 | 06:56 PM
Stevereeves's Avatar
Stevereeves
Ford calls for them to be imspected at 60,000 and replaced at 150,000 under normal operating conditions.
Old Jul 31, 2019 | 12:29 PM
High_HP's Avatar
High_HP
I replaced my front hubs (4x4) and the rear axle bearings preventatively at 150k. I'm not waiting for them to fail.
Old Jul 31, 2019 | 02:03 PM
Stoney998's Avatar
Stoney998
Stock hubs on my 08' finally had some play and growl at around 130k. Replaced by 140k and they were totally shot.
Old Jul 31, 2019 | 02:34 PM
Kountryguy's Avatar
Kountryguy
I bought my 2011 about 2 years ago with 100,000 miles. It now has about 135,000 and should probably be serviced.
Old Jul 31, 2019 | 05:46 PM
5851a's Avatar
5851a
Just had one replaced in 2012 2wd about 140k, drove it through driving wind and rain from ND to IA, parked it for several weeks and felt rumble next time I used it. Have 78 F150 one bearing has almost 300k on it other side died after driving in deep water. I think the seals will die from age and let dirt and water in.
s2gots
Jan 28, 2008 05:40 PM
tuke
Apr 23, 2007 12:15 AM
dcale101
1983 - 2012 Ranger & B-Series
Jul 21, 2006 01:44 PM
surfclam
15
Apr 7, 2005 09:04 AM
Fully_Loaded
Jan 26, 2005 08:57 PM
