Sponsored by: Real Truck
wheel bearings 'done'..HELP
Old Jan 28, 2008 | 09:14 AM
s2gots's Avatar
s2gots
What would be the simplest way to determine if wheel bearings were done?? My truck was to have had both sides done a few weeks ago at a shop...but Im starting to have second thoughts that they were done!!! Im not to much in the 'know' regarding this department. I was told when I received the estimate that they have to be pressed on?? Would the needle bearings be also replaced when doing bearing 'service'??
Old Jan 28, 2008 | 11:27 AM
Mercury45's Avatar
Mercury45
helps if we know what kind and year truck you have, also if it was the front or the rear????
Kenny
Old Jan 28, 2008 | 01:17 PM
Biggziff's Avatar
Biggziff
According to his profile he has an 04 F350
Old Jan 28, 2008 | 01:24 PM
SpringerPop's Avatar
SpringerPop
4WD or two?
Old Jan 28, 2008 | 01:25 PM
s2gots's Avatar
s2gots
fronts.....
Old Jan 28, 2008 | 02:01 PM
Mercury45's Avatar
Mercury45
the bearings on your year are a sealed unit assy, the only thing pressed on up there is the main knuckle seal...
it dont sound right
kenny
Old Jan 28, 2008 | 03:15 PM
s2gots's Avatar
s2gots
it is 4wd....could they be talking about just the needle bearings??
Old Jan 28, 2008 | 05:40 PM
Mercury45's Avatar
Mercury45
how much did they charge you, the needle bearings do not need to be pressed in (i used a piece of pipe and tapped mine in) and the bearing is a torrington B-2110 and theres one per side
the bearing is about 8 bux each
Kenny
