sway bar advice
Old Sep 18, 2019 | 11:40 AM
  #46
acadianbob's Avatar
acadianbob
[QUOTE=17 Oaks;18855883]The stiffer the anti-sway the firmer the ride is the RESULT and it does not cause more side to side rocking. You want rocking take the sway bar off!/QUOTE]
Well, we are both right. I was talking about unloaded ride. An anti-roll bar definitely imparts more side-to-side rocking as the truck hits road imperfections (like going into a gas station at an angle). It is because the truck is so stiff on the roll axis that you feel every imperfection that hits one rear wheel and not the other.
And you are right about roll control when pulling a fifth wheel or if you have a slide-in camper. They are a HUGE help in that way.
Old Sep 30, 2021 | 07:53 AM
  #47
John07's Avatar
John07
Do I Need a Sway Bar for My Travel Trailer? the answer is have because even if you observe preventive measures, there is always the risk of unknown forces causing your travel trailer to roll. Having a stabilizer bar under your travel trailer’s chassis can minimize the threat of sway and improve road safety. A sway bar for travel trailer is an aftermarket accessory that RV owners install in their travel trailer’s suspension to improve its handling characteristics. Sway bars work by controlling wheel suspension action, keeping the travel trailer’s wheels in constant contact with the road surface.
Old Dec 1, 2021 | 08:50 AM
  #48
acadianbob's Avatar
acadianbob
Try hitting a driveway curb at an angle and then tell me about rocking. By the way rocking is different than rolling. It is an anti-roll bar. The lack of roll causes additional side--to-side rocking on a uneven surface.
C_Smitty
Feb 28, 2026 11:02 AM
F350GK
Dec 4, 2017 05:16 AM
OkieSweetness
May 5, 2017 05:20 PM
Shogunles
6.7L Power Stroke Diesel
15
Feb 26, 2015 08:22 PM
SpokaneJim
Apr 28, 2010 09:31 AM
