Sponsored by: Real Truck
Chassis rust
Old Jul 24, 2019 | 08:44 PM
BiggBlack02's Avatar
BiggBlack02
Chassis rust
I have rust all over the chassis of my 02 f250, it’s flaking but I can’t poke any holes through it and the inside looks rather clean, what would be the best way to go about this? Could I get away with using just an angle grinder? Or should have it sandblasted? What products should I use when putting a powder coat on it? Another question, I’m looking to put some 35s on it, would it be better to level it or lift it? What size level or lift kit?
Old Jul 24, 2019 | 09:08 PM
GOT-DRT's Avatar
GOT-DRT
I have a 2002 F350 4x4 with a leveling kit and 35/2.50’s and no rub
Old Jul 24, 2019 | 09:16 PM
KingDeleted's Avatar
KingDeleted
Depending on the severity I usually reccomend removing the bed. Sandblasting would be best but you could also needle scale everything you can, then of course some type of rust inhibiting chassis paint
Old Jul 24, 2019 | 09:33 PM
BiggBlack02
Would I have to remove the cab as well or can I get away with sandblasting while it’s on? I can try to provide some pictures after work tomorrow
Old Jul 24, 2019 | 09:40 PM
KingDeleted
Only if it’s really really bad. Generally the front stays in better shape because it gets covered in more oil and grease. I’ll look out for some pics
79 f-150 guy
17
May 3, 2011 07:32 PM
Blackwaterforge
Aug 4, 2008 09:00 PM
Bigdaddy29384
15
Mar 17, 2005 06:44 PM
ralph_the_tech
Aug 14, 2003 05:11 PM
rfgre
Jan 11, 2001 09:44 PM
