redoing my chassis, with the drivetrain in?? plus a shackle flip Q
ok i am gonna get started on putting the rust free texan body on my 1988 f-250 4wd. the trucks got a pretty toasted body, but the frames good and solid. but i figure since the body is gonna be off i should paint the chassis nice, i read on here before of guy's using por-15 rite over the rust.
my question is does this por-15 stuff work good enough to justifie 140.00 a gallon and can i paint rite over the rust with the drivetrain still in.
also i saw on here a shackle flip kit, but i couldnt find a company on the net that sold them. id like to flip the shackles all the way around to lift it but what do i do ith the center for drop brakets, the one a saw on here was a 1-ton and like i said i could'nt find a name on the kits..
POR15 is $$$, Ive used chassis saver and rust bullet before (cheaper) with the same results.
Actually if you want a good laugh I painted a toyota with rustolem rust reformer rust converting spray, then sprayed it all down with satin. Very few spots returned and I didnt even do that good of a job prepping it. Total cost 20 bucks.
A POR 15, Chassis Saver, Rust encapsulator and the like are all superior to a standard paint. You still need to prep the frame correctly though. Big rust scale needs to be removed and all WAX ,GREASE, OIL, ANY contaminant need to be removed or it will not adhear correctly
ya i figured it was a long shot, lol.. do you buy chance have a set of power 92-97 doors in your colection "with grey door panels" i'm lookin for a set...
Yes. Actually my brother does. 150 for the pair. Red with full power and Light gray witch is different than your dark gray though
i figured if i asked you probly have a set.. the truck i need them for is a 92, im not sure i that would be dark grey or light. but it looks pretty dark, if they are solid i'll take them for 125.00 either way i geuss. you can just pm me if thats fine and i'll come pick them up. thanks
94-97 are light gray
125 will not work for the red doors he has. He would sell another set of white doors w tan power door panels for 125 though
