Spare Wherl
Old Sep 16, 2019 | 07:37 PM
harmanrk's Avatar
harmanrk
Originally Posted by V10DoubleTow
Are you sure about that? The 275/65-20 has a diameter of 34.1". The 245/75-17 has a diameter of 31.5". That would mean the tread depth of the new 20" tire would need to be 1.3" to equal the 17" tire when the 20" tire is fully worn.
Regardless, a 31.5 " diameter spare isn't a good match for 34.1" tires.
I know that back in 2017 when this was discussed, someone had an web site calculator that showed the different was within the tread depth that would wear off the tire in normal use.
Old Sep 16, 2019 | 09:36 PM
Sport45's Avatar
Sport45
Originally Posted by mwheue
How important is it to have the same circumference tire? I have 275/65r20's and the spare is 245/75r17 ? I would say quite a difference! Would a 20 fit the space allowed?
It’s not terribly important unless you have a clutch type limited slip axle. With e-lockers (unlocked) or unlocked front hubs the axle really doesn’t care if the tires are an inch or three different diameter. It’ll drive just fine until you get the road tire fixed and reinstalled. If you have a limited slip rear end it would be better to put a mismatched spare on the front axle but it’s not the end of the world if you don’t.
Old Sep 16, 2019 | 11:32 PM
mwheue's Avatar
mwheue
Thanks for the replies. I would feel better with a matching spare if it will fit the space. If not the one I have will have to do.
dsamuels
2015 + Expedition & Navigator
May 25, 2021 09:58 AM
homerj
May 12, 2018 06:34 PM
Xsuperdutyfan
Nov 30, 2017 07:58 PM
1spitfire
2009 - 2014 F150
Sep 8, 2012 04:32 PM
saddlebum13
May 27, 2009 11:45 AM
