Weird issue..need help/guidance...
Old Jul 22, 2019 | 10:13 PM
sking0621's Avatar
sking0621
Have a 2017 cc fx4 Lariat f250 with 44500 miles. While driving or even sitting idle the air bag light will come on and my AC system will shut off completely and be unresponsive. Even my electric windows will stop working. Once air bag light cuts off then things return to normal. Does this on and off quite a bit at times and at other times will do fine and not have any issues at all. Would like to have this fixed or do myself however i do not know where to begin. Any help would be greatly appreciated.
Old Jul 22, 2019 | 10:19 PM
Redrockerstl55's Avatar
Redrockerstl55
Corroded Connectors by the spare. Known issue.
Old Jul 23, 2019 | 08:46 AM
sking0621's Avatar
sking0621
Thank you!! I checked the two connectors attached to the rear frame and sure enough, there was black residue and corrosion all inside of it. I was able to clean as much as possible and add dielectric grease to the connector and reassemble. All others looked ok. Hoping this helps. Thank again for the help.
Old Jul 23, 2019 | 09:50 AM
f350ktm's Avatar
f350ktm
Please report your results.
If this does not work there was another thread some time ago reporting similar symptoms that ended up being a defective connector in the dash
Old Jul 23, 2019 | 10:18 AM
sking0621's Avatar
sking0621
Will have to drive a few days to see if corrected. Will def post final results. can you link me to the previous post mentioned so I can look this up in advance in case of continued problems
Old Jul 23, 2019 | 11:52 AM
f350ktm's Avatar
f350ktm
See Post #24 of this thread...
https://www.ford-trucks.com/forums/1...-fix-it-2.html
Another thread of interest...
https://www.ford-trucks.com/forums/1...issues-11.html
Bodiead
Jul 3, 2019 08:54 AM
rtbright
Sep 18, 2012 07:14 AM
mainecorrado
Jul 17, 2008 12:02 PM
hillbilly1025
Escape & Escape Hybrid
Nov 1, 2007 06:34 AM
