2017 Superduty - Major Electronic Issues
#151
Some of y'all are making me nervous about modifying my truck at all. I paid cash for the extended warranty and obviously don't want to void it. I'm thinking about eventually replacing the bumpers - something much heavier duty, possibly with some of those nice LED's in them. I'm also thinking about lights bars or the like for the extreme darkness we get up here. My truck didn't come with the upfitter switches option. Might have to call the dealer and see what they'd charge me to add it in...?
#152
#154
I found this odd electrical issue when I returned home from a business trip and let my wife use it while gone. Essentially mine caused random electrical things not to work when I hit the brakes and the airbag light came on. Windows, automatic mirrors, radio control etc...
I called Ford and it was going until the end of week before they could even look at it so I came to FTE. Man what a great resource this site is. Found this thread and found the connector in question. I took it apart and it looked clean with maybe a hint of wet inside. I was expecting to find it all corroded and rusted in there. So with a road trip to Tulsa for a volleyball tournament coming this weekend I just got a hair dryer out and hit it on high heat for several minutes at any angle I thought water could get in. Put it back together and all the problems had disappeared except for a burnt out tail light bulb. I am going to put dielectric grease in it and add it on for inspection/replacement next time I get serviced. Hope this helps anyone else having this issue with out the connector really looking like the culprit upon first look. I doubt this method will help one in as bad a shape as the pic earlier in this thread.
Note: The connector in question is the big Grey one on the frame. Very easy to get to.
#155
#158
Harness fixed and still hyperflashing
So they replaced bad harness, but turn signals are still hyperflashing (oem halogens).They replaced light control, still hyperflashing. So they call me and say they have to check with ford. When they do that they have to tell them, I added factory fog lamps. Which he said shouldn't have anything to do with the problem. I'm waiting for ford to give me grief on that. Before I took it in, I removed all my LEDs, and changed outage back. This water in the harness is a big problem. I just hope they dont try blaming my factory plug and play foglamps on this.
anyone have a thought on this?
QUOTE=johndrush;17476234]Any help or insight will be greatly appreciated.
My 2017 Ford Superduty 6.7L Powerstroke with Lariat Ultimate Package (with 8k miles) has all of the following symptoms.
I dropped it off at the dealer yesterday and just received a call that 3 wiring harnesses near the spare tire have water intrusion and are fried.
They are stating parts and labor are not covered under warranty will cost $1,788.00 to replace these 3 harnesses then commence further testing.
In my opinion, automotive wiring harnesses should be one of the most water-resistant designed items on these highly-electronic vehicles.
Can you imagine buying a Ford Raptor and taking it off-road to get these type of results???
I am nauseated about having a brand new $70k Superduty with these problems!
Symptoms
Symptoms
- Blind Spot Information System Failure
- Cross Traffic Alert System Failure
- Power Running boards very intermittently working.
- Air Conditioner System Intermittent failures to permanent failure.
- All hardwired dash controls non-responsive.
- Driver Seat and Steering wheel changing positions while driving.
- Blinkers intermittently responding as if they are burned out.
- Accessory/Auxilary Power System will not shut off.
- Engine Compartment light remaining on.
- DRL Lamps on while the truck is off.
- Air Bag warning light.
- Driver and Passenger Window Controls (on Driver's side) non-responsive.
- 12V Charging system to trailer failure.
- Batteries require disconnecting to ensure truck power is off.
#159
New to this forum but want to say thanks to all these post. I have a 2019 F350 and things went to crap the other day got all the same issues....currently the vehicle is at the dealer they couldn't figure out what was going after finding this I sent them the info and now am waiting for their response. Hopefully they will be smart enough to at least look. All I know is that I had all the same symptoms and although it sucks that this issue is out there it was nice to know that I'm not the only one and that its nothing I did, dealer said at first which was upgrade to LED bulbs.
THANKS
THANKS
#160
Received 6,680 Likes
on
Dock/Rocker
2017+ Super Duty
06-08-2022 10:06 AM
dkms2k
1997-2006 Expedition & Navigator
04-04-2010 08:39 PM
