Sponsored by: Real Truck
2016 factory keyless entry
Old Aug 18, 2019 | 02:19 PM
  #31
m-chan68's Avatar
m-chan68
Thank you for the update!!!
It is much appreciated to hear the outcome become a success. If you don't mind, would you be able to go into a little more detail about you needed to do with Forscan to enable the feature? As you already saw, I was unable to find where this function needed to be enabled under the programmable parameters menu in IDS. I am aware that every module has what's called "as-built" data Ford calls it. When I read your updated post, I went to pull up the as-built data for the BCM in my truck. I saw a bunch of fields where the numbers 0001 appear. So with that said, if you don't mind describing in detail what you did, and where you saw those numbers, I'm sure others who desire installing a factory keyless entry into their Super Duty truck would appreciate it as well. Good job 👍
Old Jan 22, 2024 | 09:44 PM
  #32
adamflyer's Avatar
adamflyer
Trailering
I just wanted to say thank you for updating us. I have a '13 F-350 XL. I took the door panel off and don't have the plug for the keypad either but it looks like there is hope.
Old Sep 15, 2025 | 07:35 PM
  #33
NHNorthWoods's Avatar
NHNorthWoods
Trailering
2016 Factory Keyless Entry
I realize this is an old thread. I am currently doing this to my truck. How did you get a 5 digit code?
Originally Posted by Dugansbw
So here’s what I’ve gathered that I’ll need, using the supplied door harness part number.
Will the the truck be able to be programmed to make it all function? I already have the 5 digit code so I assume it could.
Obviously I’ll hook it all up and make sure I can get it all working before I cut a hole in my door haha. But I am willing to make the effort to have the factory keyless entry.
Please give honesty input if you don’t think it will
I appreciate all the help greatly
Kentucky F150
2009 - 2014 F150
Mar 3, 2016 09:52 AM
jeffdoerr
2004 - 2008 F150
Dec 7, 2013 09:56 AM
wyleone
1997 - 2003 F150
Dec 7, 2013 06:13 AM
edouble33
2004 - 2008 F150
Jan 18, 2012 05:24 AM
kwhite
2009 - 2014 F150
Feb 9, 2010 10:17 PM
