F150 Upgrades
Old Jun 16, 2009 | 11:06 AM
edouble33's Avatar
edouble33
F150 Upgrades
Is it possible to Add the door security keypad to a truck originally without it.
Any one now of a thread or website to Add Superduty fog lamps to a F150 that does not have fogs?
Old Jun 16, 2009 | 11:15 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Door Keypad - Yes. But only if your truck has the Keyless Entry (key fob) already.
You need to buy a Door Handle with the keypad, or buy the wireless keypad
If you get the wireless keypad, it is essentially a key fob with combo lock. Program it to the truck and your set.
If you get the new door handle with inset keypad, it's pretty much a plug and play.
Old Jan 16, 2012 | 02:56 PM
bmvtr's Avatar
bmvtr
tylus do you know if the harness in the door had a plastic plug that was gray? i recently took my door apart to look into this mod.
Old Jan 18, 2012 | 01:18 AM
DieselBeast01's Avatar
DieselBeast01
If it has keyless entry, then it should already be prewired for the keypad.
Old Jan 18, 2012 | 05:24 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
If it has the keyless entry, the vehicle will already have a preset door code when using a factory inset door handle / digit pad combo.
I put a Ford aftermarket digit pad on my daughter's 2010 Focus and as Tylus said, it's essentially a key fob that's mounted to the door as it's wireless.
dannyg1992
Apr 14, 2014 05:43 AM
ocastellan
2004 - 2008 F150
Aug 21, 2011 03:56 PM
barnhill910
2004 - 2008 F150
Aug 21, 2011 03:25 PM
duke5150
2004 - 2008 F150
Feb 10, 2011 04:24 PM
Patatoe1
Electrical Systems/Wiring
Dec 2, 2005 07:25 AM
