transmission /filter ? flush J mod?
Old Jul 22, 2019 | 07:12 AM
pancake52's Avatar
pancake52
i have a 1998 e 150 4.6 engine conversion van and will be doing a trans fluid flush, not sure which trans is in my van , it does have 14 bolts holding the pan on, VIN # 1FDRE1467WHB86137. My dealer prep statement says it is a elect. auto o/d trans? But most other ID stickers are missing. thought it was a 4r70 like my 1995 thunderbird. Are the trans oil filter the same between the different transmissions. anyone know the correct /best type of filter to use?
Has anyone done the j mod to their E150 transmission?
Old Jul 22, 2019 | 08:29 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You have a 4R70W transmission.
Old Jul 22, 2019 | 12:59 PM
pancake52's Avatar
pancake52
Trans flush
Ok thanks Mark. It's what I thought it is, so now I'll pick up a filter. I'll be following your flush process. I,m doing the trans flush because it's got a hard shift at about 35 to 40 MPH, I hope that will help it. Any words on the J mod.
Old Jul 22, 2019 | 07:57 PM
Mark Kovalsky
I used to work with Jerry, who created the J mod. He knows the 4R70W as well as anyone. But I don't, and I don't know what the J mod does. But if Jerry created it, it's probably worth doing.
Old Jul 23, 2019 | 10:51 AM
Sam I Am's Avatar
Sam I Am
This is what your van had when it left Ford
Primary Features
Build Date: 08.06.1998
Vehicle Line: Econoline
Body Style: Regular Van
Version: 150
Engine: Windsor 4.6 SOHC EFI
Transmission: 4R70W (AODE) 4-Speed Auto Trans
Drive: LHD RWD
Axle Ratio: 3.55
Emission: With 49 State Emission Requirements
Air Conditioning: Manual Air Conditioning
Paint: Dark Tourmaline
Minor Features
  1. Mocha 83
  2. Untrimmed
  3. 138"/3505MM Wheelbase
  4. RV Prep Version
  5. Lorain Plant Build
  6. With Power Equipment Group
  7. With RV Conversion Upgrade A
  8. With RH 2nd Row Flip Open Window
  9. With Fixed Rear Window
  10. With Bin Type Console
  11. Floor Cover - Carpet Ins - Partial
  12. With Carpet Floor Covering
  13. With Illuminated Sunvisor - Drivers
  14. With Sound Insulation Pack Level 1
  15. With Drivers Power Mirror
  16. With Passenger Power Convex Mirror
  17. Trailer Tow Prep Pack
  18. Regular Van
  19. With Door Entry Remote Control Unit
  20. Front Bumper - Steel Chromed
  21. Rear Bumper - Steel Chromed
  22. With Front Licence Plate Bracket
  23. With Passenger Air Bag
  24. With Exterior Tyre Carrier
  25. 7J x 15 Alloy Wheels
  26. With Handling Package
  27. 3.55
  28. Ford Axle Type
  29. Windsor 4.6 SOHC EFI
  30. 4 Wheel Anti-Lock Braking System
  31. For Unleaded Fuel
  32. Leather Steering Wheel
  33. With Speed Control
  34. Heater/AC Prep Pack-Deluxe
  35. Heavy Duty Alternator
  36. Elect Premium AM/FM Stereo/Cass/Clk
  37. With Light Group
  38. Dark Tourmaline
  39. 150 Series
  40. 4R70W (AODE) 4-Speed Auto Trans
  41. Econoline
Old Jul 24, 2019 | 05:05 AM
JWA's Avatar
JWA
I have no direct knowledge of the J-Mod but I do see it mentioned very, very often in any forum where Ford transmissions are discussed----it does seem to be overwhelmingly positively received by those who've either DIY or had it done by a professional shop. If I were in a place it would be possible to perform I'd do it out of pure curiosity.
Old Jul 31, 2019 | 03:10 PM
pancake52's Avatar
pancake52
Thx for all the input from folks! Mark,Sam,JWA i did the flush and was immediately impressed with the driving results. Smooth and improved shifting , no more shuddering at 40 mph on the acceleration to 60 mph. wish I had done it sooner (thought it was a ignition issue). almost like getting a horsepower increase.
Info . I had my mechanic do a JMod to my 1995 ford thunderbird , 10 years ago , before the j mod , the 4r70 trans shuddered. quite a bit in spite of 2 flushes,. After the Jmod , shudder was gone and it had very fast upshift . kind of like a kick in the pants with a manual trans. I still have the the car going on 225k with original trans. It was worth it for 400 dollars. There is a u tube video on the process .
Old Aug 1, 2019 | 04:09 AM
JWA's Avatar
JWA
Mark K's article really simplifies this flush and it is indeed possible for just one person to do this. Apart from not walking back and forth to the ignition switch I'm not sure how a second person could make it easier?
Along with the YouTube stuff there's a lot of info available here as well: TCCoA J-Mod 4R70W. Thanks for the impressions of the J-Mod to your own 4R70W--good to know it really is a good idea.
Old Aug 1, 2019 | 03:00 PM
Mark Kovalsky
I've only done it once with a second person. That person worked the key and moved the shift handle as needed while I watched the flow. All the other times I've done this I did it by myself.
Tormz
Nov 19, 2012 08:47 AM
empiretc
104
Oct 6, 2010 07:54 PM
mx256
23
Feb 20, 2007 08:47 PM
bigdawg460
Jul 10, 2006 09:29 PM
dmueller71
Mar 12, 2006 03:40 PM
