Hazard Switch Wiring
Old Sep 22, 2019 | 04:56 PM
Vandy23's Avatar
Vandy23
Thanks to all who guided me! Received all needed parts to install emergency flasher **** and light. Got everything to work after poking around with the dash wiring!
I ‘I have a few more questions concerning the gauge cluster...it may have already been asked and answered so I apologize in advance. My original dash does not have the extra alt and oil gauges, but I just order one off of eBay to use as a compliment to my original cluster as I am in the process of restoring it to the correct colors. If I wanted to use the extra gauges what is involved with integrating them into the existing wiring ? What other parts would I need? Is it worth it? Final question, what is the cardboard like connector found on the back of the gauges called? One of mine crumbled apart when removing to clean gauge. Are these available? Purpose?
Thanks all in advance!
Old Sep 22, 2019 | 06:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Oil & Amp gauges were optional.
When you bought the round & sweep speedo instrument cluster bezels from Ford, there were no holes for these gauges.
Carpenters reproduction plastic chrome sweep speedo cluster bezel doesn't have the holes either.
A hole saw is required to make the holes.
Old Sep 22, 2019 | 06:34 PM
Vandy23's Avatar
Vandy23
Thanks. The one I bought has both of the extra gauges already installed. From there where do I go?
Old Sep 23, 2019 | 04:04 AM
Crop Duster's Avatar
Crop Duster
Here is a link to the last thread about those gauges and wiring. https://www.ford-trucks.com/forums/1...s-65-f100.html
Old Aug 24, 2020 | 01:35 AM
1900FORD's Avatar
1900FORD
Hi I have a brake light malfunction problem. I also have a emergency flasher on my truck which is a 66 f 100. I bought the ford wiring diagram book which shows two versions of the turn signal one without 4 ways and one with. They are definitely different. You need to see the diagram too make sense of yours. Most auto mechanics dont understand it so I find im on my own as far as wiring . good luck.
TitusDH
Jun 2, 2018 05:11 AM
jaggermk
Oct 13, 2015 02:02 PM
frigerator
Jan 12, 2015 05:54 PM
The Frenchtown Flyer
1947 and Older Ford Trucks
Aug 12, 2007 10:21 PM
dstruble
May 27, 2006 10:11 PM
