Anyone have a wiring diagram for a '56 turn signal switch. Finishing up ez-wire harness, and using the stock column. All else seems to be working well. Thanx for any help!!!
According to mid fifty catalog:
red wire- stop light switch
blue wire- flasher
yellow wire- left rear
White w/blue stripe- right front
green w/ white stripe- left front
green wire- right rear
Note: Turn signals override brake light switch when on. Stop switch wires go to either switch post.
blue wire- flasher
I know I am going to look dumb here (worse than I already do), but we have a flasher built in? Where is it..am I blind?
No, in the day the flasher was either just hanging on the wires under the dash or clipped into a metal clip similar to a broom clip somewhere under the dash. It's only been recently that the flasher was on the fuse panel.
If you are looking for it, it's a silver metal can ~ 2" long x 1" diameter.
Ohh...I was thinking 4 way (emergency flasher). You are talking about the turn signal flasher. I will crawl back into my hole now.
Yep 4 ways are newer yet. LOL! You dang young kids! There was even a time long long ago when you had to stick your arm out the window and signal which way you were turning...
One more question though, I have the EZ mini harness, not sure where the hazard flasher lead goes???? I know it needs to go to a switch but I am using the stock column?? Can i use any switch?? The lead is energized with 12v at all times? thanx hope im not being confusing?
