Power Distribution
Old 07-13-2019, 06:54 PM
money pit 69's Avatar
money pit 69
money pit 69 is offline
Power Distribution
Hello, I'm working on transplanting my 97 4.0l into my B2. I'm in the process of mounting the power distribution box under the hood.
My question is there is a black wire at the end mounted to a cross bar with 2 bolts. The wire is about 1ga. big .
Is it a ground or power I'm asking because I thought I read some where black on some years was hot just checking..
Old 07-13-2019, 08:36 PM
ranger pat's Avatar
ranger pat
ranger pat is offline
Old 07-31-2019, 10:34 AM
money pit 69
Pictures of 97 ranger harness.
Well I did some meter checking and determined that that black wire was the power wire for the buses on the power distribution box. Thx for that link helpful in the future.
I have this plug with no mate can anyone tell me where it goes. I'm thinking ICM but I can't find it. Thx again
Old 12-12-2020, 12:24 PM
money pit 69
Hello guys I'm back working on my 87 B2 with the 97 Ranger 4.0l transplant. I'm really struggling with the wiring. Sometimes it's hard for me to get across what I'm needing. I'm using the 97 under hood wiring harness which is completely hooked up to the engine , transmission and transfer case. I'm also using the under hood PDB which will power the engine. This is where I'm confused .The PCM is plugged in and hooked to the engine harness with no harness wire break out for power. So how does it get it's power. The PDB has a fuse for + power and a PCM relay power that go to engine connector C124 but from there I'm lost.
Note: I'm using the old B2 wiring for lights and such. I have the B2 ignition switch turning the engine over.
Old 12-13-2020, 12:45 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Did the 97 vehicle from which the transplanted 4.0L engine & wiring harness came from, have PATS anti theft ???
RIJID-FORD
Electrical Systems/Wiring
05-22-2012 05:40 PM
Jeepers2003
12-02-2010 05:25 PM
Ford_Eddie_Bauer
06-19-2010 09:44 AM
Sycostang67
05-01-2007 08:54 AM
AirTran
11-28-2005 01:02 PM
Quick Reply: Power Distribution
