Oil change stuff
Old Jul 13, 2019 | 11:08 PM
z31freakify's Avatar
z31freakify
Imagine all those engines with side mounted oil filters, they be dead lol..... Nothing wrong with not pre-filling an oil filter.
Old Jul 14, 2019 | 05:44 AM
Wilson00PDD's Avatar
Wilson00PDD
How often does the oil filter go into bypass mode? It is my understanding that most filters will bypass during a cold start anyway.
And if the bypass is on the dome end of the filter it will have traveled across the dirty side of the filter element possibly picking up contaminants as it bypasses.
I would say pre filling the filter or not is a non issue in the big picture.
That said I have always pre filled my filters as long as they're mounted vertically.
Old Jul 14, 2019 | 08:59 AM
'88 E-350's Avatar
'88 E-350
In '95 I was maintaining a fleet and a Ford rep told us to pre-fill the oil filters, but I have no idea what his level of expertise was or who told him this. I always pre-fill large filters like what's on the 7.3. I can't imagine new oil having dangerous particles in it so as long as I don't introduce any it seems like it should be safe. Many say that the bypass valve opens on cold starts meaning that unfiltered oil goes through the motor anyway.
As for larger filters, it seems that most gearheads like to find the biggest filter they can fit no matter what vehicle it is. The FL-1995 is already pretty damn big, about twice the size of the filter on the 6.7. I wouldn't bother with a larger filter unless it was a better filter. One with a by-pass filter would interest me.
Old Jul 14, 2019 | 10:03 AM
RA101725's Avatar
RA101725
Banned
I seriously doubt pouring new oil into the unfiltered side will hurt anything either for that matter, unless some unscrupulous toddler was putting sand in there while you had your back turned or something. What can I say I like to live on the edge and push my luck with this stuff.
Old Jul 14, 2019 | 11:15 AM
00t444e's Avatar
00t444e
I agree, your putting 14 quarts of it in the crank anyway, so why worry about the little bit that goes in the filter.
Old Jul 14, 2019 | 12:22 PM
SaintITC's Avatar
SaintITC
Originally Posted by Sous
I only have input on the Fumoto valve.
I installed one on my truck a couple years ago and it allows me to drain the oil into a couple of empty gallon containers so that I can easily turn them into an auto parts store for recycling.
I liked the Fumoto drain valve so much I bought one for our Subaru as well. Now I can change the oil and filter on the Subaru and the truck on the road when going cross country with little to no tools.
I give the valve a
I put drain valves on everything, the truck, wife's Flex, mother-in-laws Accord, my TR6. Everything that I do maintenance on. One less threaded boss on an oil pan to screw up, and a hose into a used oil bottle. I'd put one on the oil filter if I could...
Old Jul 14, 2019 | 12:50 PM
RA101725's Avatar
RA101725
Banned
I poke a hole in the bottom of the oil filter with a 2lb sledge and a center punch and let that drain out at the same time.
Old Jul 14, 2019 | 12:56 PM
Wes444's Avatar
Wes444
Well that big bypass filter i use is almost 4 quarts to prefill vs the 2 of the FL1995, that's quite a chunk of capacity, but i agree with your point.
Old Jul 14, 2019 | 12:58 PM
Wes444's Avatar
Wes444
Make sure that you loosen the filter first tho
The hole becomes a point of no return if u are in a rush
Old Jul 14, 2019 | 09:47 PM
RA101725's Avatar
RA101725
Banned
I only hand tighten it. With a pair of clean hands and you can get it pretty damn tight. I have the wrench but have never used it.
Turbo Dog
2009 - 2014 F150
Dec 12, 2016 10:45 AM
Tom
2009 - 2014 F150
38
Oct 8, 2013 09:35 AM
bulletpruf
34
Apr 1, 2010 08:30 AM
Mathwiz
2004 - 2008 F150
21
Nov 9, 2004 05:18 PM
fightercowboy
1997 - 2003 F150
20
Aug 26, 2004 12:39 AM
