I have a 2019 F350 Lariat Crewcab 6.7 with rear camera, in bed lights and 5th wheel plug. Does anyone know if there are any extra unused wires going from the engine compartment to the rear of the truck?
I’m not aware of “extra unused wires going from the engine compartment to the rear of the truck”. My understanding is that these are four short pass-through wires in the front passenger footwell.
What are you trying to do?
HTH,
Jim / crewzer
I'm going to install some supplemental backup LED lights powered by one of the upfitter switches. If there is already a wire pulled I won't have to pull one for the lights. Was hoping someone with access to a wiring diagram could take a look and see if a spare was already in place. Since the truck already has all available options associated with the bed it's unlikely there is a unused plug in the wiring harness back there. Seems like I read someplace that there was a single spare wire at one of the tail light plugs. Haven't looked yet.
The upfitter switch harness is bundled up under the fuse- and relay boxes in the driver side engine compartment. It shouldn’t be too difficult to run an extra circuit from there to the back of the truck.
