Coolant leak
Old Jul 7, 2019 | 06:46 PM
pkthomas's Avatar
pkthomas
Coolant leak
So I drive my Excursion very little. And when I do it normally it is towing our camper. The last few tows I have noticed a coolant smell. No leaking, not over heating. Saturday I had the same smell when we got home, less than 10 miles. Had a small puddle under the truck this time. So today I went to HF and got a test kit. Pumped it up, no leak. But could smell coolant. So I started it under pressure. Coolant flies put from behind the fan.
So any surgeons on a water pump brand? And what temp thermostat?
Old Jul 7, 2019 | 09:39 PM
WE3ZS's Avatar
WE3ZS
What engine do you have?
Old Jul 8, 2019 | 06:47 AM
pkthomas's Avatar
pkthomas
I have the 7.3.
Old Jul 8, 2019 | 08:34 AM
ArmyLifer's Avatar
ArmyLifer
I went with the “OEM” water pump from Riffraff. Still good after two years. There are spirited discussions on thermostat temps. I went with stock (194?), but I live in the south. Others say at 203 the engine is more efficient. Still others want a 180 for towing heavy. Made my head hurt.
You might get more action over on the Diesel 7.3 forum.
Old Jul 8, 2019 | 09:10 AM
pkthomas's Avatar
pkthomas
Thanks for the input. I may post over there.
Old Jul 8, 2019 | 09:11 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
How many miles on it?
I replaced mine a couple months ago. It was definitely leaking from the shaft. If you loosen the belt and can wiggle the fan then that it a real good indication that the bearing and seal in the pump are going. I just used a local parts store replacement one.
Old Jul 8, 2019 | 11:04 AM
pkthomas's Avatar
pkthomas
The water pump has less than 15k on it. I bought it local a few years ago, NAPA maybe. I found a Gates on Amazon for $52 and a 192° thermostat. I think that is the way I am going.
Old Jul 11, 2019 | 11:32 AM
pkthomas's Avatar
pkthomas
The water pump will be in today, and hopefully the thermostat will be in by Saturday. Now if the rain will just hold off this weekend.
bcg
18
Mar 21, 2016 04:54 PM
98FordTruck
Jan 15, 2009 06:31 PM
98FordTruck
1997 - 2003 F150
Jan 14, 2009 09:13 AM
95X15
Feb 9, 2005 04:23 PM
FourthFordTruck
4 Cylinder Engines
May 25, 2004 09:04 AM
