Sponsored by: Auxito
Coolant Leak
Old Jan 13, 2009 | 03:17 PM
98FordTruck's Avatar
98FordTruck
Coolant Leak
I have a 2005 Explorer that is leaking coolant from somewhere in the front. It only seems to be leaking when I park it in my garage and stops after the engine cools but not when I leave it outside. When I turn the vehicle off I can hear the coolant boiling from through the dash. I am thinking that it is time for a flush. If I had to guess, I would say that the reason it only leaks when parked in a heated garage is because the temps have been around anywhere from -40 to -60 up here in Alaska so when I leave it outside it cools down quick enough to where it doesn't boil out. Are these two issues related and is there anything else that could be causing it to leak?
Old Jan 14, 2009 | 09:13 AM
powrstrkn''s Avatar
powrstrkn'
If I read your post right you think that the coolant is boiling in the engine?
boiling coolant is never good.
I would fist check around the weep hole on the water pump.
How much coolant does it leak, how many miles on the truck
I just noticed that this is an '05 it might be better answered in the appropriate forum.
MFJ
29
Sep 8, 2014 12:46 AM
98FordTruck
Jan 14, 2009 09:23 PM
Ford_Six
Garage & Workshop
13
Sep 22, 2005 06:16 PM
dustinleavitt2000
17
Jun 27, 2003 04:07 PM
Casey's Dad
Jun 23, 2003 07:25 PM
