223 Heat Riser
Old Jul 7, 2019 | 12:33 PM
Indybeer's Avatar
Indybeer
223 Heat Riser
Anyone have pics of the 223 heat riser position when the eng is cold and when it is up to temp. Mine isn't stuck, but doesn't seem to be working like it should.
Old Jul 11, 2019 | 05:28 AM
Indybeer's Avatar
Indybeer
one time bump
Old Jul 11, 2019 | 02:05 PM
Aaron81's Avatar
Aaron81
Weight should be horizontal when cold, and rotate and drop vertical when hot. It may take a little RPM from the motor to get it to drop even when hot.
Old Jul 11, 2019 | 11:22 PM
Mixer man's Avatar
Mixer man
FYI.
https://www.hemmings.com/blog/article/all-rise/
Old Jul 12, 2019 | 09:37 AM
abe's Avatar
abe
Originally Posted by Mixer man
Interesting and informative article. Thanks for sharing.
My 54 still has the heat riser. My 55 had the riser replaced by a spacer by the PO.
Old Jul 12, 2019 | 09:55 AM
Matt Js 54's Avatar
Matt Js 54
That is interesting, I haven't started mine yet, but when I had the manifold off it was frozen closed. I put some PB Blaster to it and worked it loose, and now it moves easily. The spring is not doing anything, though, has anyone found a place to get a replacement bi-metal spring for it? Might not be worth it, that might be a project for another time.
Old Jul 12, 2019 | 12:17 PM
Mixer man's Avatar
Mixer man
They are abundant. Too many sources to list.
https://www.google.com/search?client...39.7tWasMxHOig
Old Jul 12, 2019 | 12:24 PM
Mixer man's Avatar
Mixer man
My heat riser is frozen solid. I would attempt a repair or replacement if I had a good spare manifold set for the updraft carburetor found on COE's. They are next to impossible to find.
Old Jul 12, 2019 | 12:32 PM
Aaron81's Avatar
Aaron81
NOS are on ebay many times, that is where I got mine. The spring should hold closed, and then once it is hot, and you rev the motor lightly, it should rotate open. Mine is new, so that is maybe why I need to rev ever so slightly, or it isn't hot enough sitting and not driving...
Old Jul 18, 2019 | 12:55 PM
Matt Js 54's Avatar
Matt Js 54
Mine was too, squirt some PB Blaster down on the shaft on the inside and outside, it will probably work loose. Mine moves easily now, I didn't do anything special. I'd think you'd want it stuck open, if you have to choose one...
Old Jul 19, 2019 | 10:44 AM
Mixer man's Avatar
Mixer man
Miner was too, squirt some PB Blaster down on the shaft on the inside and outside, it will probably work loose. Mine moves easily now, I didn't do anything special. I'd think you'd want it stuck open, if you have to choose one...
I'm thinking it is stuck in the open position because it takes so long to warm up and settle down. I have to pull the right front wheel to get easy access to the carburetor and heat riser, and I don't want to even breathe on that manifold because replacements are almost non-existent. I'll try your tip when I get a chance.
ajorn
6.7L Power Stroke Diesel
Nov 8, 2018 11:32 AM
EFranzen
54
Jun 25, 2017 09:50 PM
Money-Pit
Nov 4, 2013 05:27 PM
dpmp154
Nov 21, 2008 05:45 PM
Michael Littman
Florida Chapter
13
Jul 16, 2004 10:14 PM
