2002 E250 w/5.4 gas engine----the #5 COP bolt insert pressed into the manifold has lost its grip and is spinning when trying to remove the COP bolt----as it is now I cannot remove the COP and plug for replacement. There are several ways to repair or re-install the threads but I need a way to remove the bolt and COP first.
I've considered using a drill bit large enough to eliminate the bolt head which would probably work. I've already tried using a pry tool to add upward pressure in hopes of the pressed-in insert pulling free without any luck. I'm being careful to not damage the intake so nothing more than light pressure is applied. Anyway........
If anyone has a way to remove the bolt when the insert is loose---please share!
At least it's #5 and not #4 or #8.
I would try to drill from the side until the hole is part way into the insert. Then stick a finishing nail or something in there, or drive a screw in and leave it, to keep the insert from spinning while you turn the bolt out.
Oh yeah on the location---if there's an upside to working on a van its that I have slightly better access to these fricking bolts.
Hmm I'm having a tough time envisioning this process though. I'm wondering if drilling the head with large enough bit to remove it allowing the COP to lift straight up and out then wrestling with the insert to remove or re-install it with JB Weld or the LocTite Thead Repair Kit.
Use a left handed drill bit, it may grab and back out the bolt if you are lucky.
No that won't do what I need----the bolt AND insert are turning just fine which is exactly what I don't need happening. The COP is basically trapped against the intake and I'm trying to remove it without damage to the intake or any of the bosses holding the threaded inserts.
I had to use a dremel/oscillating saw to remove the stripped head bolt on my #8 just recently. I was able to get my dremel/oscillating saw under the head of the bolt and sheared it off there. Once you have the COP out of the way, you'll have all the room you need to work. Just cut it. It doesn't take long and saves you a hell of a time.
PS. Make sure you have a replacement bolt on hand before starting (obvious, but sometimes we all miss the obvious)
