I pulled heads on my 1998 5.4 and I broke them down to lap the valves to reinstall I put springs back keepers did not mix any thing up ..question is now all my valves are closed do I Install the cam or wait until the head is back in the block..reason I m asking is my concern w timing ..when re installing the cams,do the lobes on the cams automatically put the valves where they are supposed to be ..if so is there any way to get this wrong in terms of timing
Reason: Mis spell
I would not install the cams until the head is properly torqued down. The stress from torquing the cams could affect if the heads get torqued properly. I would install and torque the cams only after the heads are torqued and all of the timing marks are in their correct positions
Has to be the problem because I don't think timing is my issue I think it is the heads properly sealing .my compression in each cylinder is all over the place ..is it really possible that installing the cams first is warping my head's and do I need to have them machined now..I only torqued the cams at 8 ftlbs I beleive is correct
And in sequence ...
